Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007 and Newer Expedition and Navigator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2007 and Newer Expedition and Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
Is F-150 Still King?
  #1 (permalink)
Old 10-15-2009, 11:35 PM
fire3110's Avatar
fire3110 fire3110 is offline
fire3110 is starting off with a positive reputation.
Aftermarket Navigation
I have an 08 Expo EL with the 6 disc CD changer in the dash. It also has the factory DVD system for the rear seats and steering wheel controls? Does anyone make an aftermarket replacement radio with built in navigation and so I can still use the steering wheel controls and be able to properly operate the rear DVD entertainment system? I am particularly looking for a Pioneer but any suggestions would be great?
  #2 (permalink)
Old 10-16-2009, 01:02 AM
tylus's Avatar
tylus tylus is offline
Navy Nuclear Mach. Mate
2008 Ford Expedition
tylus has a good reputation on FTE. tylus has a good reputation on FTE.
all of the aftermarket units support the steering wheel controls...if you buy the little adapter of course.
Pioneer is probably top of the line, and you get a quality product...but it will cost you a pretty penny.
I highly suggest you look at the JVC units. Run you about $800. Touchscreen, Nav, iPod/MP3, Bluetooth...fun stuff.
You need a Double Din radio to replace your current radio. Single Din will fit, but you'll need an adapter plate to fill the blank space.
isn't the rear DVD stand-alone? what functions of it do you want to maintain? 99% of the aftermarket units have audio and video RCA inputs. so you should be able to use the center DVD outputs and get sound via the Expy speakers...and video on it's screen.
just make sure to find a unit that is at least Dual Zone, and hopefully Tri zone.
__________________
2008 Expedition EL - Hers....Bone Stock
2009 Mustang Bullitt - Mine..Not Quite Stock
Currently deployed. See y'all on the flip-side.
  #3 (permalink)
Old 10-17-2009, 09:45 AM
shorebird's Avatar
shorebird shorebird is offline
Wage Slave
2008 Ford F-150
shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all
Keep in mind the cost of updating the nav maps info. $300.00 is about the average cost of new disks. A net book running Microsoft Streets and Trips is a great alternative.
__________________
2001 E-350SD V10 Triton 3.73LS; '05 & '07 Taurus SEL's;
2008 F-150 FX2 Sport 5.4L 3.73LS Scab 145" Wb
Unique Collision Center Towing & Recovery Specialist
“Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
  #4 (permalink)
Old 10-18-2009, 10:49 AM
Freak4Ford's Avatar
Freak4Ford Freak4Ford is offline
Freak4Ford is starting off with a positive reputation.
Upside to portable navigation unts are the upgrades are usually a free download, when you get rid of your vehicle you keep the unit. The downside is the cables.
__________________
2004 Navigator Ultimate 4wd
Superchips Tuner
Aero Exhaust S/S Muffler
MagnaFlow S/S Resonator
22" wheels
305/40 tires
  #5 (permalink)
Old 10-18-2009, 12:24 PM
08 Navigator 08 Navigator is offline
08 Navigator is starting off with a positive reputation.
I would look for an OEM unit on eBAy or in a junk yard. I had an after market (Pioneer) unit in my 07 town car, and it never worked as well as the OEM units I've had in other cars.
My 08 Navigator did not come with Navigation, and it was plug and play when I found an OEM unit on eBay. Everything instantly synced up, even the Sirius radio subscription. You don't need to install a roof mounted GPS antenna, I used a generic under the dash antenna and it works perfectly.
Good luck
  #6 (permalink)
Old 10-18-2009, 04:24 PM
shorebird's Avatar
Wage Slave
2008 Ford F-150
A net-book with a $15 GPS puck antenna can also be used for internet access at WI-FI sites while traveling. Add a cellular wireless My-Fi ( Sprint: Meet the MiFi ) and you have access while moving.
__________________
  #7 (permalink)
Old 10-18-2009, 09:35 PM
fire3110's Avatar
Do I need to buy the generic under dash antenna seperate and if so where do I get it? Thanks.
  #8 (permalink)
Old 10-18-2009, 10:16 PM
Quote:
If you put in an OEM system, Ford has a generic antenna that works with all their systems that sells for about thirty bucks. They are available from Ford or on eBay. Use 3M double stick tape (it's made for installing trim on the outside of vehicles) to stick it up under the dash. If you need help sourcing parts, PM me and I'll give you the name of the Ford Radio distributor in Chicago.
  #9 (permalink)
Old 11-12-2009, 09:35 AM
04markIII's Avatar
04markIII 04markIII is offline
04markIII is starting off with a positive reputation.
i run an eclipse unit in my expedition. they are usually rated higher than pioneer and don't cost as much. i have use of my steering wheel controls and my rear dvd player.
__________________
2003 Ford Expedition: 5.4L, harley supercharger, 6lb lower pully, c&l plenum, k&n cai awaiting install, LFP SBTB, FTSP, Magnaflow 3" catback, 2006 F150 20's, 2800 stall converter, Hawk brake pads, Drilled rotors, Eclipse AVN-5510, white face gauges, cobalt c2 boost gauge, 339 rwhp, 440 rwtq(dynoed with oem 17's)
  #10 (permalink)
Old 11-12-2009, 04:34 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is starting off with a positive reputation.
Quote:
How many adapters did you need to retain the dvd and steering wheel controls?
__________________
2008 Expedition Eddie Bauer 4x2
1978 F250 Lariat 4x2
Tags
2001 , 2009 , aftermarket , dvd , entertainment , f150 , f250 , ford , fx2 , market , navigation , oem , radio , system , systems , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
