Arizona Chapter Join Chapter, Leader:
Sealant for oil leak on timing cover
Old 03-29-2002, 07:31 PM
460lover's Avatar
460lover
460lover is offline
Is there any type of sealant(spray or otherwise) that I could use to help with an oil leak on the timing cover on a 460. I can't afford (time mostly) to replaced the seal at this time.
Old 04-02-2002, 05:03 PM
Water Dog's Avatar
Water Dog
Water Dog is offline
If you can get to the timing cover, you can clean around it very well with MEK, must be oil free, and then smear on some silicone sealer with your hand.I recommend that you ware disposable rubber gloves.I have done this in the past and it is only a temparay fix.If it is leaing around the crank shaft you are out of luck.:
FORDS WILL STILL BE RUNNING WHEN ALL THE GENERAL MOTORS JUNK IS ON THE SCRAP HEAP!
Old 05-26-2002, 10:53 AM
HEFTY F350's Avatar
HEFTY F350
HEFTY F350 is offline
Something else to keep in mind. If you have an oil leak that just wont quit. There may be another cause. The crank case builds pressure. If this pressure is not vented (pcv valve), you will have oil coming out of the weakest sealing area. If your engine has a few miles on it, this is most likely to be the valve covers, front seal or rear main seal. They all have an abundance of oil being splashed on them constantly.
A troubleshooting aid is to take a piece of paper about the size of a dollar bill. Remove the oil filler cap and lay the paper over the opening. Watch to see if the paper is being blown up or being sucked down. If it is being sucked down, your pvc system is working the best it can. If it is being blown up, check the valve for vacuum and flow.
A pcv valve can only flow so much. Good luck.
Old 05-26-2002, 11:24 AM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
diyster
Escape & Escape Hybrid
12-10-2015 12:24 PM
ollirrap
25
01-01-2015 08:31 PM
royt911
09-22-2010 12:24 PM
6LPSD
1999 to 2016 Super Duty
13
06-10-2010 04:13 PM
T18skyguy
06-05-2010 06:50 PM
Quick Reply: Sealant for oil leak on timing cover
