Pull up to the pump, insert the pump into filler neck, squeeze handle.
Seriously, you're good to go. If you've never run it, I would recommend having some spare fuel filters on hand. Bio is a good solvent and it will clean the junk out of your tank depositing it into your filters, etc. You'll want to change them a couple times after you start running it. Good luck.
