1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Royal Purple in the LS differential
Old 10-16-2009, 07:14 PM
bpounds's Avatar
bpounds
bpounds is offline
Originally Posted by 06silvercrew
No matter how you cut it, 75w140 is expensive!!!!
It is. I mean, IT IS!!!
Got to the store and they only had 2qts of RP, so I got Mobil 1, 75W140, limited slip instead. It was a buck cheaper anyway. Only $17.99.
Old 10-16-2009, 08:13 PM
EXv10's Avatar
EXv10
EXv10 is offline
Originally Posted by Krewat
Funny thing. My rear diff made a slight whine at highway cruise from brand-new. Never changed, never got any better, but was so slight it wasn't worth doing anything about.
Had to clean up the rear cover, changed out diff fluid to royal purple.
Noise got a LITTLE bit quieter, but didn't go away.
Had a leak, had to fix it, and tried Mobil 1 this time.
NO NOISE.
As for the LS additive, are you sure it has the additive, or it's billed as "not requiring it"?
There is 2 versions of Mobil 1; 75-140 synthetic. Regular and the LS version which has the additive. That is an interesting observation with the addition of the Mobil 1 ! Sometimes the ring and pinion don't mesh perfectly from the factory, I has seen this also.
Old 10-16-2009, 08:16 PM
EXv10's Avatar
EXv10
EXv10 is offline
No matter how you cut it, 75w140 is expensive!!!! I have 60K on the clock and have a nice finned aluminum cover sitting in the garage, but damn near $70 for 4 qts of liquid gold LOL
That's because they don't make a lot of it.
Old 10-16-2009, 09:06 PM
06silvercrew's Avatar
06silvercrew
06silvercrew is offline
But its still far cheaper then buying 75w90 from GM......Stuff lists for over $35 a quart.
Old 10-17-2009, 12:35 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
I used the stuff without the additive, and added it in small increments until the chatter went away My LS (stock) actually works
Old 10-17-2009, 03:26 PM
ameinig's Avatar
ameinig
ameinig is offline
Right. I know it has been discussed before, but the purpose of the LS additive is to make the LS NOT work. That is why it reduces chatter.
Old 10-17-2009, 07:28 PM
EXv10's Avatar
EXv10
EXv10 is offline
No, there is a fine line between worky and no worky. Don't add too much.
01raptor
17
03-30-2012 10:47 AM
danday0404
02-10-2010 10:12 PM
Rich in CO
1997 - 2003 F150
11-13-2006 07:24 PM
Fordman_Evs
05-25-2006 10:31 PM
Quick Reply: Royal Purple in the LS differential
