76 F100 shifter problem
Hello Guys. I have a 76 F100, 3 speed manual on the column. with power steering. I need to know if anyone knows where I can get the replacement steering shaft that goes through the column. It seems like the only ones I can find are for manual steering. Mine has grooves worn in it and I need a replacement. I checked all the local Junk Yards and can't find anything. Thanks for the advice. Alex
Much to my surprise, I found one!
According to the parts catalog, the automatic and 3 spd columns use the same shaft.
Shaft Assy., Steering
73-up F100-350 2WD and power steering w/o tilt from s/n S40,001
D3TZ-3524-D
33 3/8" long 46 knurles on shaft OD for upper bearing
Haven Ford, Haven, KS shows 1 (620) 465-2252
D3TZ-3524-D
redbulldog
01-19-2003 06:35 PM
