4.9L Firing order??? - Ford Truck Enthusiasts Forums
Old 10-15-2009, 03:30 PM
88PONY 88PONY is offline
88PONY is starting off with a positive reputation.
Hello all....dumb question, wheres # 1 cylinder on my 96 F150 4.9L? Closest to the fire wall or to the radiator? I have a check engine light and its says # 1 cylinder is running to lean so I think I might have an intake leak.
Thanks
Old 10-15-2009, 04:02 PM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
front , by radiator.
1-5-3-6-2-4
Old 10-15-2009, 04:08 PM
Cool, my trouble codes are p0301 and p0147. i think it might have and intake or exhaust leak. it has a ticking noise when you hit the gas. i know its not a valve tap or anything like that. code p0301 is #1 cylinder misfire.
Old 10-15-2009, 04:37 PM
quicklook2's Avatar
a little more info:
It is 1-5-3-6-2-4.
( also , the distributor rotor turns CLOCKWISE , the distributor cap is installed with the marked # 1 position facing AWAY from the engine , and the engine cylinders / spark plugs are numbered 1 through 6 , from front to rear )
See this page,1992 Ford Firing Orders
google is your friend.
Old 10-15-2009, 04:43 PM
ok i know the caps the wrong way i just noticed that...lol ok so now i find out my distributors lose...is the a special way to time this truck? i'm used to the older fords you unplug the little pill by the ignition module. this truck doesnt have that, so how i go about timing it???
thanks
Old 10-15-2009, 04:50 PM
quicklook2's Avatar
it has a spout that you need to remove.
follow the wiring from dist.
10 degrees btdc with spout out.
Old 10-15-2009, 05:01 PM
ok i found it im gonna time it and see what happens. how do i reset the check engine light ?
Old 10-15-2009, 05:26 PM
ok now i feel like a royal idiot....wheres the timing tab? i marked the spot on the crank but dont see the marker on the timing cover???
Old 10-15-2009, 08:37 PM
fordinlinesix's Avatar
fordinlinesix fordinlinesix is offline
fordinlinesix is starting off with a positive reputation.
I don't know about the '96, but my '67 has little raised lines cast into the front of the timing cover on the drivers side close to the outer perimeter of the harmonic balancer.
Old 10-15-2009, 09:01 PM
i've been playing with this thing for hours and nothing i've read its on the passanger side , i've read its on the drivers side....i can't even see the mark i put on the balancer that is marked 10 degrees. i did find however that the harness going to the distributor the wires were exposed and touching so i'll go to the junk yard in the a.m. and get a new harness and start over.
Old 10-15-2009, 09:05 PM
92 f-150 92 f-150 is offline
92 f-150 is starting off with a positive reputation.
god this brings back bad memories..... i was messin with mine for almost a month tryin to figure out why it wouldnt start. to say the least the firing order and the fuel injection system is burned into my mind forever.
Old 10-15-2009, 09:08 PM
it runs fine its a souther california truc so its never see any weather below 50...lol its in mint condition too. i just noticed the distributor lose. all day long and i still cant figure the damn thing out i just wanna time it already....lol
Old 10-16-2009, 02:14 AM
ok i've been looking all night long at my truck and pics from what i see on the internet. my truck looks like it has a crank trigger on the passanger side....how can that be if its got a distributor??? i'm so lost maybe cause its a california emissioned truck???
Old 10-16-2009, 07:19 AM
fishforlife2007's Avatar
fishforlife2007 fishforlife2007 is offline
fishforlife2007 is starting off with a positive reputation.
the timing tab should be right by the crank pulley. at first i couldnt read mine so what i did is spray the hell out of it with some brake kleen, gave it a lil scrub(easier to do from under the truck), and another shot of brake kleen, and then a shot of compressed air and it showed up like new. there was just so much crudd built up on it over the years... if you wana try to give your truck a lil extra pickup, set that timing at 12 deg. i was suprised with the difference when i did it to mine..
Old 10-16-2009, 01:20 PM
ok i cleaned it and still see nothing. does anyone have a pic of what it looks like?
4.9l firing order Ringwood1 1987 - 1996 F150 & Larger F-Series Trucks 19 11-15-2016 07:31 AM
Firing order problem for my 4.9L inline 6 DarrellA Ford Inline Six, 200, 250, 4.9L / 300 9 08-11-2016 03:45 PM
4.9l having trouble starting warm JoePhoto Ford Inline Six, 200, 250, 4.9L / 300 31 04-20-2016 06:57 PM
4.9 300 electronic ignition, orange spark on 4 5 6 tropicalnapo 1973 - 1979 F-100 & Larger F-Series Trucks 4 04-02-2013 10:51 AM
86. 4.9 (L6-300) No fire from distributor on cylinder 6. cartmans_twin 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 32 12-21-2011 08:11 AM
Tags
1986, 1987, 1992, 49, 49l, 96, cyl, engine, f150, firing, ford, misfires, order, set, timing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
