Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-15-2009, 03:53 PM
claudiucenan claudiucenan is offline
claudiucenan is starting off with a positive reputation.
Trunk Door Does't Open (Escape 2001)
Hello.
Yesterday I bought a Ford Escape 2001 the car is very nice, but already I have a problem.
I can open my trunk door or the window (front the trunk door).
Maybe someone had this problem because I don't know what to do.
I search for the recalls but nothing similar with this problem.
I hope that someone could help me.
Thank you .
  #2 (permalink)
Old 10-15-2009, 07:49 PM
ovenking ovenking is offline
ovenking is starting off with a positive reputation.
found the cure
I had the same problem with our rear hatch. Intermittantly working and then not working at all. After looking in the search engine on this forum, under "rear hatch won't open" I found a posting listing the part # for the solenoid only, from an aftermarket source. (Ford makes you buy the whole handle and actuator assy. for $200 or so). The solenoid was $10 plus shipping. Installation was straight forward except the rod that connects the solenoid to the mechanisim needs to be modified and the wires spliced instead of the modular plug on the stock one. If your not that mechanical, you may want the stealership to do it , but if you have some skills, you can save alot of money! (If Ford had put a freaking key hole on the rear hatch it wouldn't be such a big deal) Search the threads and you will find the post for the part. Hope this helps.
__________________
2003 F250 6.0 diesel, 2001 escape,1999 F150 V6 extra cab
  #3 (permalink)
Old 10-15-2009, 07:59 PM
I found it
same problem on my 01 Escape. replaced solenoid with unit from Parts Express online. Sku 330-582. After removing 4 screws from inner hatch trim cover and snapping out cover, the complete assy is exposed. Remove 1 phillips screw and 4 10mm nuts and assy comes apart. I then replaced the solenoid with the aftermarket unit(you will have to bend the included rod to match fit because it doesn't have same rod as the factory unit). Then wire the new unit to factory wiring(green to pink and blue to pink with black stripe. Done in 1 hour total. Price for solenoid $10.50, price if you have to buy whole latch assembly from Ford $147.00. (Ford only offers complete latch, lock, handle as a part)
__________________
  #4 (permalink)
Old 10-16-2009, 08:57 AM
Thank you.
I don't know what to do because is working now but not all the time.
Yestarday I separet the remotes because I had 2 remotes from to different cars and for my surprise was working but not all the time.
Ok, if doesn't work anymore I'll try to do yours ways.
If somebody can give me another option, I'm hear.
Thank you again for all guys.
  #5 (permalink)
Old 10-16-2009, 02:26 PM
I fond the part Sku 330-582 to Parts-Express.com:Omega DS2.1SQ Lock Actuator | actuator door lock power locks power door lock plunger.
You can confirm me that this the part??????????
Thank you, thank you.
  #6 (permalink)
Old 10-17-2009, 11:13 AM
aj7885 aj7885 is offline
aj7885 is starting off with a positive reputation.
rear hatch
Here is the original thread on that problem.
http://www.ford-trucks.com/forums/80...k-problem.html
  #7 (permalink)
Old 10-17-2009, 03:32 PM
Thanks.
I'll do like that and I bought the part from the site.
I hope that I can fix the probleme because I don't like this situation.
Ciao
Tags
01 , 2001 , actuator , assembly , back , door , escape , ford , hatch , lock , motor , open , rear , trunk , wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
