Block Heater for 2006 6.0 Diesel
- I'm looking for any tips and recommendations on using the block heater. The Owner's manual says for use at -10 degrees F. I live in New England so at times the temperature can get that low, but is it worth it to use the heater at or near 32 degrees or colder? How long can the block heater be plugged in for? Will using the heater frequently cause damage to any components or systems of the truck? Any tips or suggestions would be great.
I've got a 2003 with a 6.0. I plug mine in anytime the temps drop to 40 or lower. Once it starts getting cold, that 15-40 starts getting thick. When you start your truck with cold, thick oil, it's puts extra strain on everything including your batteries and starter! When you do plug it in, the truck starts up like it's 80 degrees outside.
Like most others, I take the dogs out one last time about 10PM and plug up the truck. I get up and let the dogs out about 530AM. I let the dogs out, fire up the truck and let it idle until I get the dogs back in...maybe 5 minutes or so and then I'm off.
Plug it in, you'll notice the difference!
Joe
Joe
