engine weight - Ford Truck Enthusiasts Forums
engine weight
Old 10-15-2009, 09:24 AM
cookieman69 cookieman69 is offline
cookieman69 is starting off with a positive reputation.
engine weight
hello, I am trying to decide what v/8 engine to put in my 1955 f-100 it came with a 6cyl. were can I go to get the weight of the various ford motors I always had my heart set on 429 but someone told me that would be to heavy for my f-100 also does the c/6 trans have overdrive, thanks, Mike
Old 10-15-2009, 09:32 AM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
This might be what you're looking for.......
http://fixrambler.com/engineweightchart.txt
Old 10-15-2009, 09:39 AM
53OlderThanMe's Avatar
53OlderThanMe 53OlderThanMe is offline
53OlderThanMe is gaining momentum as a positive member of FTE.
The C6 does not have overdrive, look to an AOD for that.
Old 10-15-2009, 10:53 AM
Old F1's Avatar
Old F1 Old F1 is offline
Old F1 has a good reputation on FTE.Old F1 has a good reputation on FTE.Old F1 has a good reputation on FTE.
Quote:
Lots of 429/460 in 48-56 trucks. Replace the pig iron intake with aluminum and the cast iron exhaust manifolds with headers and even the cast water pump with an aluminum one and if a frail and weak old memory works you are down to about what the Y block v8 would be in weight.
Old 10-15-2009, 11:36 AM
GreatNorthWoods's Avatar
GreatNorthWoods GreatNorthWoods is offline
GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.
I don't know what your six weighs but the 429/460 is heavy at 720 pounds. Compare that to a 351W at around 550 or a 289/302 at 460. My guess is that your six is around 375-400 pounds. The old straight axle will handle the extra weight or if you go with an IFS you can adjust it with the proper coil springs.
Old 10-15-2009, 11:58 AM
Old F1's Avatar
Ford Y block V8 625 ibs. (272-312 CID)
Old 10-15-2009, 10:59 PM
bnradams's Avatar
bnradams bnradams is offline
bnradams is starting off with a positive reputation.
Old F1 is closer to the weight, my 292Y is a bear to work with on a stand. If I ever pull it again Ill be getting a stronger one!
Old 10-16-2009, 12:35 AM
Julies Cool F1 Julies Cool F1 is offline
Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.
A couple of things to remember:
First as was mentioned, the intake manifold on a 429 or 460 is going to weigh about 100 pounds. Using aluminum will shave off a bunch.
Second this frail little solid iron bohemoth truck is rated to carry over 1000 pounds of extra weight so an extra 150 poundes above a stock 239 flathead, or Y block isn't going to hurt it. That's probably as much as one of th etwo passengers you will sit in the cab.
I have a 390 FE in my 51 with a C6. It's fine, you arent going to hurt it if you want to pu ta 429 or 460 in it - weight wise. Now space is a different matter all together.
Old 10-16-2009, 08:56 PM
deyomatic deyomatic is offline
deyomatic is starting off with a positive reputation.
Anyone know of a similar chart showing weights of popular transmissions? I'm curious to know how much the Fordomatic that was in my F100 weighs...It LOOKS heavy.
Old 10-16-2009, 09:45 PM
That Ford-O-Matic is very heavy at 228 pounds.
Here are a few others....
Ford -O-Matic - 228lbs
FMX - 160lbs
C4 - 110lbs
C6 - 140lbs
AOD - 150lbs
Old 10-16-2009, 10:41 PM
Thanks for that! I haven't separated the engine/tranny but it just looks like a bear. Do you know if that number includes the torque converter?
Old 10-17-2009, 07:23 AM
Quote:
I've always assumed that it did include the converter but not fluid...but I can't say for certain. It's hard to imagine the Ford-O-Matic is 228 pounds WITHOUT the converter!
Help Me Understand My Truck's Capabilities AKHunter93 1987 - 1996 F150 & Larger F-Series Trucks 27 05-09-2016 05:42 AM
52 F-1 weight before and after Rimrock F1 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 10-24-2015 01:36 PM
weight of 1050 ford F-6 ldj1002 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 03-24-2015 08:59 AM
TV receiver hitch questions TexasA&M 1999 to 2016 Super Duty 7 07-18-2011 03:41 PM
curb weight 66 f100 nayrb65 1961 - 1966 F-100 & Larger F-Series Trucks 5 06-08-2009 04:12 PM
Tags
292, 429, 460, chart, engine, engines, find, ford, iron, pig, recall, specs, truck, v8, weigh, weight, weights
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
