Front reciever hitch for 98 explorer - Ford Truck Enthusiasts Forums
Old 10-14-2009, 11:42 PM
85F_150driver's Avatar
85F_150driver 85F_150driver is offline
85F_150driver is starting off with a positive reputation.
Does anyone know of a company that makes one for the 98's i see Curt manufacturing makes one for a 99 - 01. Whats the difference in the 98 and 99 I thought they were the same body styles. Thanks in advance for any info.
Old 10-20-2009, 08:23 AM
cobrajeff_1965 cobrajeff_1965 is offline
cobrajeff_1965 is starting off with a positive reputation.
Front Receiver Hitch
I have one off my 2000 Mountaineer. I had it custom-made from a rear hitch. I ordered a front hitch from Draw-Tite
many years ago, but found out that their front hitch (which was listed to fit BOTH Explorer AND Mountaineer) did NOT
fit a Mountaineer - the hitch receiver did not come out in the right place.
I designed brackets for this one, and had a professional welding shop fabricate and weld them to it.
If you get close to White Lake (Waterford area), you're welcome top stop by and see if this one would work for you.
Right now, I'm working on fabbing a front hitch up for my Lincoln Aviator - which nobody offers. I'm modifying one
for a 2005 Explorer/Mountaineer to make it work.
Jeff
Old 10-20-2009, 08:37 AM
Wizard1946 Wizard1946 is offline
Wizard1946 is starting off with a positive reputation.
Maybe I'm just old or something, but what do you use the front receiver for?
Old 10-20-2009, 08:42 AM
I live on a small lake - I use the front hitch for pulling my boats in and out of the water, and moving them around on my property.
I also use it to manuever my 18' car-hauling trailer into a tight spot next to my garage. MUCH easier to do looking forward, instead of craning my neck looking back over my shoulder.
Jeff
Old 10-21-2009, 08:20 AM
Thanks, I was just curious. I have front mounted tow bar brackets on mine and pull it behind my motorhome when traveling. Makes sense to have it when moving things around.
Old 10-22-2009, 09:05 PM
donnor donnor is offline
donnor is gaining momentum as a positive member of FTE.
front receiver uses
A front receiver can also be used to carry bikes - especially handy if your rear receiver is occupied towing a trailer.
dn.
Old 10-23-2009, 01:17 AM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
If you are into wheeling you can mount the winch either front /back where ever is most convenient to get you out of trouble.
I also mount my snow plow via a front receiver.
Old 10-24-2009, 09:50 AM
CobraGT40's Avatar
CobraGT40 CobraGT40 is offline
CobraGT40 is starting off with a positive reputation.
Quote:
dn.
That's awesome ! I never even thought of that !
Thanks !
Scott
lift kit dunnerjeff 1999 to 2016 Super Duty 4 01-21-2015 06:54 AM
Will the IAC in a 99 throw a code? Shernius 1997 - 2003 F150 6 10-30-2009 07:54 AM
Main differences between early & late '99 drewk 1999 - 2003 7.3L Power Stroke Diesel 1 12-04-2006 08:06 PM
Lowering kit for 98 Navigator (4WD) joners 1997-2006 Expedition & Navigator 6 09-11-2003 07:24 AM
differences between 97-98-99 Expys? mcmary10 1997-2006 Expedition & Navigator 7 01-20-2002 02:30 PM
Tags
1998, 2003, 2010, 98, bronco, explorer, f150, ford, front, hitch, receiver, reciever, sport, tow, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
