Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Early Broncos (1966 - 1977) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-14-2009, 10:15 PM
ksmith203's Avatar
ksmith203 ksmith203 is offline
ksmith203 is gaining momentum as a positive member of FTE.
76 bronco ignition switch removal..
I want to put a new ignition in because the old one was pulled and they used a screwdriver to start the bronco. Is there a trick to get it out or is it pretty straight forward?
__________________
1969 N600 wrecker on its way. Frame and drive train done...Waiting on cab from sandblaster.
  #2 (permalink)
Old 10-15-2009, 07:19 PM
Boba Fett Boba Fett is offline
Boba Fett is starting off with a positive reputation.
Pretty straight forward... if the key tumbler is not in it..... The screwdriver will not hurt the switch if that is what you are worried about.... the keyed tumbler does the same thing as a common screwdriver.......
  #3 (permalink)
Old 10-21-2009, 11:19 PM
powerstroker02 powerstroker02 is offline
2002 Ford F-350
My Garage
powerstroker02 is starting off with a positive reputation.
hello, i just did one not to long ago, well if you lost a key or dont have one like me you needa drill the tumbler and basically rip the dam thing out. to install a new onethere is a pin hold at the bottom of the tumbler, when you install it thats the simple but if u ever need to remove it for some reason or other you insert a pin into that hole while its in the accessory mode then u keep turning it un the whole tumbler moves then u can take it right out again
Tags
73 , 76 , 87 , bronco , cylinder , drilling , early , ford , ignition , install , installing , switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
