4.6 with a possible bent valve - Ford Truck Enthusiasts Forums
Old 10-14-2009, 09:59 PM
hotrodlincoln69 hotrodlincoln69 is offline
hotrodlincoln69 is starting off with a positive reputation.
I just picked up a very cheap 97 F150. After driving it I noticed a misfire so i changed the plugs. All the plugs looked good other than #8 was black. A compression test revealed zero compression on that cylinder so I pulled the valve cover. The rocker arm had fallen off so I loosened off the camshaft and slid the rocker back in and torqued the cam down and put everything back together. When I fired up the engine it sounded like the valve hitting the piston. I am assuming there is a bent valve and that is likely the reaon for the rocker coming off. Any other suggestions or oipinions?
Old 10-14-2009, 10:25 PM
Stillen GLE Stillen GLE is offline
Stillen GLE is starting off with a positive reputation.
Yup, what was the compression for all of the cylinders? how did everything else look in there. take pics next time.
Old 10-24-2009, 01:08 AM
mattjensen mattjensen is offline
mattjensen is starting off with a positive reputation.
i had a 00 with the 4.6, bent a 4 valves, broke the rocker arms. Do not know what the deal was with that.
No compression in #1 cylinder Ricardo Babirad 1994.5 - 1997 7.3L Power Stroke Diesel 7 03-09-2016 10:12 PM
93 F150 4.9L engine trouble Milpool 1987 - 1996 F150 & Larger F-Series Trucks 8 01-31-2016 11:13 PM
302 rocker issues 84XLF150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 12-17-2015 12:37 PM
Re-visiting the death shake...... Eric Kropp Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 12-03-2014 11:27 PM
bent pushrods/bent valves stevetford Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 02-02-2010 05:39 PM
Tags
2006, 46, 46l, 54, arm, bent, f150, ford, rocker, rockers, shooting, trouble, truck, valve, valves
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
