Compression check 97 f-150 4.6l
Old 10-14-2009, 07:01 PM
riverbottom's Avatar
riverbottom
riverbottom is offline
My 97 f-150 4.6l overheats and has excessive pressure in system. I suspect a blown head gasket. I'm preparing to do a compression check. Could anyone tell me what would be a normal reading on the compression gauge?
Old 10-15-2009, 01:55 PM
eallanboggs's Avatar
eallanboggs
eallanboggs is offline
You're not looking for "normal" you're looking for a "narrow range". You read all the cylinders and you don't want to have any one cylinder more than 15% below the highest. All engines wear differently so you can't predict what engine compression will be after 100K miles, but you can say they should all be pretty close to each other(withing !5%). If most are 140 and one is 75 that's a problem to look into. Do the test dry first then wet. If a cylinder fails both wet and dry do a leakdown. If all cylinders pass dry there is no need to do the wet at that point.
kdagenais
1997 - 2003 F150
02-24-2023 04:12 PM
Chisum5013
02-04-2016 01:14 AM
Tex Ford
2004 - 2008 F150
02-02-2016 08:04 AM
notch83
6.4L Power Stroke Diesel
11-09-2012 01:02 AM
JonathanN
1997 - 2003 F150
10-19-2010 06:04 PM
Quick Reply: Compression check 97 f-150 4.6l
