240 inline 6 issue
Old 10-14-2009, 06:52 PM
cherrycityrebel's Avatar
cherrycityrebel
cherrycityrebel is offline
240 inline 6 issue
I have an '68 Ford f-100 240, manual 3-speed transmission and She has 80,000 miles. she drives great in the city at around 30-40 MPH, but once i get on to the freeway and drive at a steady 55-60 she starts to miss and doesnt want to accelerate anymore... and afterward i tend to baby her home on the back roads at 30-40 and she does this for the rest of the day til i let her sit overnight and she will be as good as new.... i need some advice thank you
Old 10-14-2009, 08:58 PM
anderson sc's Avatar
anderson sc
anderson sc is offline
fuel filter be my first thing to check.
Old 10-14-2009, 09:15 PM
anderson sc
Oh, Welcome! new here myself. Good folks here.
Old 10-15-2009, 06:48 PM
stanyol69's Avatar
stanyol69
stanyol69 is offline
as Anderson said,first the fuel filter then the fuel pump then the coil
Old 10-16-2009, 04:47 PM
cherrycityrebel
ive checked all those, do you think it could be the carb?
Old 10-16-2009, 08:10 PM
anderson sc
carb? maybe but I don't think so, do you have points are they to close, condencer going bad? loose ground or any loose wire's, key switch going bad? I've seen all types elctrical act up when temperture raises, do to engine heat or of wore or loose conections. Coil maybe only ok when cool. At this point need more info. on how you checked stanyol69's list. could you have two fuel filters? have seen one at carb. (been added)and the one below fuel tank.
Fungus232
21
08-19-2022 02:17 PM
MudhenGIB
05-11-2016 02:23 PM
Hellbringer
10-22-2014 12:01 PM
gemmBronco
1978 - 1996 Big Bronco
13
03-28-2006 03:32 AM
Quick Reply: 240 inline 6 issue
