Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-14-2009, 02:10 PM
DCRB DCRB is offline
DCRB is starting off with a positive reputation.
sloppy shifter?? did we brake something?
my mom's 95 shifter is slowly getting worse. right now it's at the point where we have to hunt for gears just to put it into park or reverse or d/od. it's not stiff like the rest of ours, hers is all sloppy and loose. she says it's been doing this for a while, but i think it got worse when i pulled her cluster out to change the light bulbs. I say this because i couldn't get the needle cable un done, so i just let the cluster rest on it while i was changing the bulbs, which put a little bit of tension on it.
__________________
93 3.0l xlt extended aerostar
mods: 800 watt sound system. - 2" catback exhaust w new flexpipe and cherry bomb muffler. - 4g alt. wiring - Gutted stock airbox.
"88 civic "STD PLUS!!"
  #2 (permalink)
Old 10-14-2009, 04:44 PM
Pablo-UA Pablo-UA is offline
Pablo-UA is gaining momentum as a positive member of FTE.
remove shofter and try to take it apart on bench, and you will know is it possible to fix it ore to get one on JY. My friend had bad shifter and we replaced it with Scorpio on floor shifter.
__________________
_____________________________________
And makes us rather bear those ills we have
Than fly to others that we know not of?
  #3 (permalink)
Old 10-19-2009, 02:23 AM
HA!!! my girlfriend figured it out. if it werent for her probably would have torn the steering column all apart to figure it out, since i had to wiggle a weird way to see that the bolts at the end of the shifter were both loose. she's smaller than i am, and was able to see them right off the bat.
any ways it was the two bolts shown in the picture below that had wiggled loose and was making the shifter all sloppy.
hopefully this thread will help others in the future
__________________
  #4 (permalink)
Old 10-20-2009, 03:31 AM
Don S.'s Avatar
Don S. Don S. is offline
1978 Ford F-150
Don S. is starting off with a positive reputation.
I will definitly check that in my girls '95 Aero, cause her shifter is so sloopy and it drives her and I nuts.
I'll come back and let you know if that fixes it on her's.
__________________
Committee: a group of the unwilling, picked from the unfit, to do the unnecessary.
"Brutus" 1978 F-150 SC 4x4 BB460
" There is a very fine line between "hobby" and "mental illness."
" -Dave Barry, Nationally Syndicated Columnist
  #5 (permalink)
Old 10-20-2009, 05:04 AM
i had sloppy steering column shifters on MB trucks and I used Therad lock.... then to change them mechanics had some pain.
__________________
  #6 (permalink)
Old 10-20-2009, 07:59 PM
xlt4wd90 xlt4wd90 is offline
xlt4wd90 is starting off with a positive reputation.
Do you think this is caused by the bolts just working themselves loose from normal use, or could it be that the driver is not always pulling up on the lever all the way, and fighting the lever locks, causing more stress than normal?
  #7 (permalink)
Old 10-21-2009, 03:41 AM
I think both. my mom said that she had been lazy and was just dragging it around, i told her not to do that because it will cause this plus could cause the shifter to brake... we had to replace one once in my dad's old 94 (rip) and it wasn't cheap, and that was ten years ago (like 200 bux)
__________________
  #8 (permalink)
Old 10-23-2009, 06:49 PM
Old Dog 2 Old Dog 2 is offline
Old Dog 2 is starting off with a positive reputation.
[quote=DCRB;8049876]HA!!! my girlfriend figured it out. if it werent for her probably would have torn the steering column all apart to figure it out, since i had to wiggle a weird way to see that the bolts at the end of the shifter were both loose.
Hey DCRB
Thanks so much for posting your fix. I have had the same problem with my 96 F150, and was just about to take the column apart when I read you post. Just fixed it and all is right again. Made my day.
  #9 (permalink)
Old 10-23-2009, 11:54 PM
you are VERY welcome! share the info around the board, i know that more than just aerostars use colum shifters (like what, every ford from like 92 to present?) and i'm sure this info will help others.
oh yeah, kate says you are welcome too. lolz
__________________
  #10 (permalink)
Old 11-07-2009, 02:15 PM
Headviking's Avatar
Headviking Headviking is offline
Headviking is starting off with a positive reputation.
What do I need to remove to get to this part to tighten?
__________________
07 F250 6.0L PSD Lariat
Dieselsite Coolant Filter
Bilstein Shocks/Rough Country Steering Stabilizer
Fumoto Oil Drain Valve
24" Wiper Blades
  #11 (permalink)
Old 11-10-2009, 03:15 PM
nothing really, i removed the plastic panel and the metal panel behind it under the steering wheel to see better but to actually get to the bolts you just crawl on your back under the dash board and look strait up, you'll see them.
__________________
Tags
1978 , 1995 , 1997 , 95 , cable , f150 , f250 , ford , lever , loose , parts , shift , shifter , sloppy , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
