Turn signal relay location?? - Ford Truck Enthusiasts Forums
Old 10-14-2009, 12:20 PM
dvldog458's Avatar
dvldog458 dvldog458 is offline
dvldog458 has a very good reputation on FTE.dvldog458 has a very good reputation on FTE.dvldog458 has a very good reputation on FTE.
Question Turn signal relay location??
I just replaced my turn signal bulbs with LED replacements and when I actuvate my turn signal it blinks very fast.
I think if I upgrade my turn signal relay to a heavy duty or electronic it should do the trick and slow things down.
I looked in my manual and could not find the location. Has anyone replaced their relay/ And if so where is it located? Or any pics would be great.
Thanks
JD
Old 10-14-2009, 01:37 PM
tdappleman tdappleman is offline
tdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to all
The blink speed is a common problem when going to LED bulbs - it's due to different resistor values of the bulbs. I had looked into doing this on a different car and bookmarked this site: Tail light and Turn Signal LED Bulbs Fix
Old 10-14-2009, 05:41 PM
dvldog458's Avatar
Nice link. Thx
I will look into it.
Old 10-15-2009, 09:48 PM
dvldog458's Avatar
Well, I installed a Napa heavy duty relay part# EP-27 and I still have the same problem.
As far as it's location....it's in a pretty chitty spot. Under the dash right of the fuse panel near the small storage compartment.
Any other ideas?
Old 10-16-2009, 06:11 AM
shorebird's Avatar
shorebird shorebird is offline
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
Old 10-16-2009, 06:25 AM
Looks like a good solution if it works... love this text from the auction:
Load resistors are a fire hazards, because they get VERY HOT.
It is like installing a Toaster to solve a simple flash problem…..
It's not like these resistors have a load going through them at all times so heat doesn't really get a chance to build up - unless you left your hazards on - maybe that would build up a bit.
Old 10-16-2009, 08:13 AM
dvldog458's Avatar
Good info guys. Thx. I just noticed this morning that when I use my 4 way hazard button they blink at a normal speed. But when I use only the left and right they blink Very fast. Does the 4 way use a different relay?
I
I
Old 10-16-2009, 03:49 PM
dvldog458's Avatar
If I have to install an inline resistor I will....but for now I'd like to find a simple push in relay/flasher.
I found this place:
LED Flashers Blinkers Resistors Load Equalizers for Turn Signal Replacement Bulbs Rapid Flashing Fix
Old 10-17-2009, 11:16 AM
RACERX7775's Avatar
RACERX7775 RACERX7775 is offline
PROFESSIONAL KNOW-IT-ALL
RACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to behold
dvldog, when i made my taillights using the 4" round tractor trailer led lights, i used the load resistors. i have had mine inside the rear taillight housing for about 2 years now. no problems.
Old 10-19-2009, 09:49 PM
dvldog458's Avatar
Thanks for all the ideas and help guys.
I went ahead and purchased the LED flasher relay fix (link above) and it works perfect. I just pushed the new relay in and it was good to go!
Old 02-26-2010, 04:25 PM
gmcbride's Avatar
gmcbride gmcbride is offline
gmcbride is gaining momentum as a positive member of FTE.
I know this link has not been active in awhile, but can someone please tell me, with some specificity, where the darn flasher is. call me stupid, but i cannot find it. i have the fuse panel off, turn on the hazard button, can hear it, but just can't locate it? thanks very much!
Old 02-22-2011, 08:42 PM
jay1000 jay1000 is offline
jay1000 is starting off with a positive reputation.
Exclamation flasher location
Thanks
JD
your flasher relay is easy to find. if look at the bottom of the dash below the radio, you will notice that the panel comes apart. it has four screws this panel is part of your cup holder and ash tray .once thats down and out of your way, look in the dash and its right in front of you. in side of a black box. remove black cover by prying it open its the blue relay in side.
Old 02-26-2011, 01:46 AM
1buckeyefan 1buckeyefan is offline
1buckeyefan is starting off with a positive reputation.
Quote:
I need to replace mine. Does anyone have a photo of where this is??
Old 02-26-2011, 06:25 AM
Paultv Paultv is offline
Paultv is gaining momentum as a positive member of FTE.
The easiest way to find it is to turn the flasher or blinker on and stick your hand under the dash where the radio is, and there is a black box, just keep grabbing things with your hand and you will feel the thing ticking, it's in the most stupidest place I've ever seen a flasher.
Old 02-26-2011, 06:05 PM
RACERX7775's Avatar
Quote:
Originally Posted by Paultv View Post
The easiest way to find it is to just keep grabbing things with your hand and you will feel the thing ticking.
sorry, i edited it a bit. thought it was funny.
1999 Expedition Turn Signal/Hazard problem johnkirk 1997-2006 Expedition & Navigator 41 03-04-2016 02:04 AM
2008 Ford Ranger Turn Signal "Relay" ?. ddardanell New Member Introductions 0 11-15-2015 08:19 PM
87 Ford E350 Signal light whaase 1968-2013 Full Size Vans 1 06-16-2015 09:32 PM
2012 E350 Turn Signal Relay location? carrfamilynj 1968-2013 Full Size Vans 1 09-13-2013 05:23 AM
Bad Turn Signal Relay? beerguy5812 Explorer, Sport Trac, Mountaineer & Aviator 11 12-11-2005 11:15 PM
Tags
04, 2000, 2005, 2008, diesel, excursion, f150, f250, ford, located, relay, signal, superduty, truck, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
