2008 F250 6.4L Diesel Fuel Filter part # - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-14-2009, 11:38 AM
ben8ent ben8ent is offline
ben8ent is starting off with a positive reputation.
About to do my first fuel filter(s) change. The owner's manual says the part # is FD4604. Motorcraft.com and dieselfiltersonline.com say the part # is FD4609. Amazon.com say both will fit my truck.
Does anyone if there is a difference between FD4604 and FD4609? Will both fit??
Thanks
Old 10-14-2009, 06:29 PM
bpounds's Avatar
bpounds bpounds is online now
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
4604 was for the 6.0L. Looks to me like 4609 is for the 6.4L.
Forget Ford, and order from these guys:
Ford 6.4 Liter Turbo Diesel Truck Filters
Old 10-15-2009, 10:42 AM
Agreed. I guess there is a misprint in the Ford manual. I did order the filters from dieselfiltersonline.com.
Thanks
Old 10-15-2009, 10:45 AM
bpounds's Avatar
2 bit Californian
You might want to visit fleet.ford.com and download a fresh copy of the manual (it's free). There are often multiple printings available. Not saying there is for an '08, haven't checked.
Old 10-15-2009, 11:07 AM
I went to the site, but I cant find the diesel supplement manual. Do you know where to find it?
Old 10-15-2009, 11:20 AM
bpounds's Avatar
2 bit Californian
https://www.fleet.ford.com/maintenan...ls/default.asp
It is found under the maintenance tab.
On edit:
I don't think they have the diesel supplement there, and that is what you need. Try here:
http://www.motorcraftservice.com
No need to log in, just click on the owners manual tab on the left side of the page.
Old 10-15-2009, 11:32 AM
bpounds's Avatar
2 bit Californian
Looks like they corrected it in the 4th printing of the diesel supplement.
Old 10-15-2009, 11:39 AM
Found it!! Sure enough, on the 4th printing of the supplement they added the correct fuel filter # to the manual for the 6.4L. The 1st and 3rd are incorrect (2nd not shown).
YOU DA MAN!!
Thanks
Old 10-15-2009, 11:48 AM
bpounds's Avatar
2 bit Californian
Glad you found it.
I think I know what happened on that. You have to remember that an '08 manual covers the Superduty and the Econoline. The Econoline still got the 6.0L engine. They just left out that differentiation. Took them long enough to fix it, huh?
Old 10-15-2009, 12:52 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
A service tip for you on the filter change I had with my 08. Upon putting on the new filters and cycling the key the 6 times per the manual my truck would not start. I could get it to catch briefly was about it.
I learned that holding down the fuel cutoff switch while cranking I was able to get it primed and running.
My switch is sensitive is the only explanation I have.
Switch is on the passenger side of the dash. Open the door and you will see the access panel on the side of the dash.
Change in fuel filters? waumpuscat 6.0L Power Stroke Diesel 3 11-23-2015 09:41 PM
Upgraded FD 4604 to FD 4616 ? Per4mance 6.0L Power Stroke Diesel 1 09-14-2013 05:19 PM
Diesel filters online.com cefloyd 6.0L Power Stroke Diesel 17 07-08-2012 05:06 PM
Fuel Filters - OEM or aftermarket ? UaVaj 6.0L Power Stroke Diesel 24 05-26-2010 12:22 PM
[Leason Learned] Don't use International Fuel Filter kit #FS19797 97C5ENVY 6.4L Power Stroke Diesel 8 11-11-2009 08:44 PM
Tags
2008, 250, 64, change, diesel, f250, fd4604, fd4609, filter, filters, ford, fuel, installation, location, replace, replacement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
