Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > The 2009 and Newer F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
The 2009 and Newer F150 Discuss the new 2009, 2010 Ford F150 SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-14-2009, 08:49 AM
Crazy001's Avatar
Crazy001 Crazy001 is offline
2008 Ford F-250
Crazy001 has a good reputation on FTE. Crazy001 has a good reputation on FTE.
No tranny dipstick?
So I while doing an oil change on my dad's '10 F150 I went to check the tranny fluid. Only there's no way to do it! How are you supposed to check this? The manual says that it's only supposed to be done by a dealer. This simply isn't good enough! There has to be a way it can be done!
I remember on the 5R55s used on my '05 Mustang there was something like an internal dipstick accessible from under the car, is there something similar here?
Also, it's pretty clear to me that the transmission temperature "gauge" is nothing more than a glorified idiot light, similar to my '08 F250. Anyone know what temperature the tranny has to get to for the gauge to indicate that it's getting too hot?
__________________
Tom,
Current truck - 2008 F250 CC 4x4 PSD
Previous Fords:
2007 F150 Screw 4x4
2003 F150 4x4 r/c auto
  #2 (permalink)
Old 10-14-2009, 09:54 AM
Mikey D1016's Avatar
Mikey D1016 Mikey D1016 is offline
Mikey D1016 is starting off with a positive reputation.
I do believe that I read about it being under the truck on the side of the transmission. I do believe that you have to be careful when checking it because it is right near the exhaust system (and you are supposed to check the fluid when its at operating temp)
__________________
Mike
09 F-150 XLT
  #3 (permalink)
Old 10-14-2009, 09:58 AM
johnwill johnwill is offline
johnwill is starting off with a positive reputation.
Quote:
So don't worry about it. You don't need a dipstick. Be glad for this time and work saving enhancement on many current vehicles.
It simply is good enough.
  #4 (permalink)
Old 10-14-2009, 11:46 AM
04XLTRUNNER's Avatar
04XLTRUNNER 04XLTRUNNER is offline
2009 Ford F-150
04XLTRUNNER is starting off with a positive reputation.
why is he worried about it. its got a 100k mile warranty on the tranny. atleast mine does. and it doesnt need to be serviced until atleast 60k miles. dont worry about it.
__________________
2009 F-150 FX4, Dark Blue Pearl, Supercrew, Sony System, Exhaust, HID's, Shorty Antenna, Optima Red Top, Daystar 2" Level Kit, 35x12.5x20 Mudgrapplers, more coming soon.....
Gone:
2005 F-150 lariat 4x4
2004 F-150 xlt 2x4
  #5 (permalink)
Old 10-14-2009, 12:57 PM
Crazy001's Avatar
2008 Ford F-250
He's not worried about it. I am!
2 months ago, my 3-month-old '08 F250 had to go in the shop with 3,000 miles on it because of a transmission output shaft leak. I saw the fluid all over the transmission crossmember and was able to check the fluid and determine that I had enough to get me there. Without a dipstick I would have risked being stuck on the side of the road with no way to add fluid. Or I would have had to wait for a wrecker...neither of which I wanted to do.
My dad's previous Dodge had a very minor transmission leak that we never found. Had around 60,000 miles on it at the time. One day he asked me to look into why it kept stalling on him. Looked online and found out that it was common for a low transmission fluid condition to cause frequent stalling. Warmed up the truck, checked the fluid and found the cause. Would not have been possible without a dipstick!
I do NOT like going to a dealer to have maintenance done, as I don't like paying $80 an hour for labor when I can just as easily do it myself. Without a dipstick, they make it VERY difficult to do it myself!
__________________
Tom,
Previous Fords:
2007 F150 Screw 4x4
  #6 (permalink)
Old 10-14-2009, 01:04 PM
2009 Ford F-150
well if there happens to be a leak somewhere, the dealer should take care of it at no cost. and if you have roadside they will come to your rescue, i know i have had to use it. thats all covered under warranty
__________________
Gone:
2004 F-150 xlt 2x4
  #7 (permalink)
Old 10-14-2009, 01:23 PM
Frankenbiker's Avatar
Frankenbiker Frankenbiker is offline
Frankenbiker has a good reputation on FTE. Frankenbiker has a good reputation on FTE. Frankenbiker has a good reputation on FTE.
The time lost to sitting on the side of the road (not to mention the danger) while sitting and waiting on said road service is more than some people care to deal with. I don't know about ya'll but I have better things to do than sit on the side of the road for 2-3 hours.
-blaine
  #8 (permalink)
Old 10-14-2009, 02:19 PM
Hybris's Avatar
Hybris Hybris is offline
Hybris is starting off with a positive reputation.
Thing that would get me is after the warranty is up not being able to check the condition of the fliud.
__________________
1999 F-150 XL 5.4, Auto, 4x4, 8ft bed, ~160000 miles Mods K&N high flow filter 2" suspension lift
  #9 (permalink)
Old 10-14-2009, 03:53 PM
wb6anp wb6anp is offline
wb6anp is starting off with a positive reputation.
I just went out and checked my truck it is an '09 and has no tranny dip stick.
__________________
2009 F-150 Supercrew Platinum in Dark Blue Pearl
2008 Escape Hybrid
2008 Tiffin Allegro 32BA Motorhome on a Ford F-53 6.8l V10
http://community.webshots.com/user/wb6anp
  #10 (permalink)
Old 10-14-2009, 06:33 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is starting off with a positive reputation.
It does have a dipstick, just not in the traditional sense. It's on the body of the transmission.
Transmission Fluid Level Check:
NOTE: Should only need to be done if transmission starts to slip, shifts slowly or shows signs of transmission fluid leaking.
NOTE: Transmission fluid temperature must be between 175 and 185 degrees F (80 and 85 degrees C) when checking fluid level. Vehicle must be level, preferably on a hoist. Vehicle needs to be running and in PARK while checking fluid level.
1. With engine running, place transmission selector in each gear position and hold each gear for approximately 5 seconds.
2. Remove transmission fluid fill plug located on the passenger side front portion of the transmission case.
3. Separate transmission fluid level indicator from transmission fluid fill plug.
4. Wipe transmission fluid level indicator clean. Reinstall only the transmission fluid level indicator back into the transmission fluid fill plug hole to check transmission fluid level.
NOTE: Transmission fluid level must be at the upper level of the crosshatch mark. Do not overfill transmission.
5. Reattach transmission fluid level indicator to transmission fluid fill plug. Reinstall transmission fluid fill plug assembly and torque to 26 lb-ft (35 Nm).
__________________
2008 Expedition Eddie Bauer 4x2
1978 F250 Lariat 4x2
  #11 (permalink)
Old 10-14-2009, 07:42 PM
Some how my post didn't get edited, It should have said it has no visible dip stick it is under the truck on the right hand side.
__________________
2008 Escape Hybrid
  #12 (permalink)
Old 10-14-2009, 08:47 PM
Greg B Greg B is offline
Greg B is starting off with a positive reputation.
It's just another example of Ford valueing shareholders more than customers. Every little thing that Ford does to make things more difficult for their customers is one more little thing that they hope you go to the dealer for. And it probably saves the company $.25 or so per vehicle. It would be nice if the price of the vehicle would reflect the savings instead of escalating each year.
  #13 (permalink)
Old 10-15-2009, 02:11 AM
Hammerhead1550 Hammerhead1550 is offline
Hammerhead1550 is starting off with a positive reputation.
Well I for one like to do preventive maintenance on my cars and trucks, and checking the level and color/condition of fluids ranks at the top. If you think not checking transmission fluid levels saves time then wow. How long does it take to pull a dipstick and check the readings, 5 seconds? As for the people saying don't worry about it the warranty covers it, yes it does and a free tow, but does that help you when you break down at nite and they tow your truck to a closed dealership that doesn't open till the moring? What if you are on a trip and this happens, are you going to sleep in the truck all nite till the dealer opens, when you could have added a quart of fluid and been on your way till you could get to your destination and then let them tow it and have it fixed.
  #14 (permalink)
Old 10-15-2009, 02:15 AM
I know Canton makes a dipstick kit for Mustangs that lets you add a dipstick to the transmission, hopefully they will make on for our trucks also. I was also wondering if the dipstick and tube from and expedition with the same engine and tranny combo would fit our trucks.
  #15 (permalink)
Old 10-15-2009, 10:20 AM
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is offline
Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE.
2 things that come to my mind....
1. Sounds like your dad never used the dipstick anyway if he let the dodge get to the point where it was stalling....
2. Its not a matter of ford not valuing customers....its a matter of vehicles progressing and owners refusing to. The tranny doesn't need to be touched for 100,000 miles..... its the same thing as sealed wheel bearings.....sure we can't repack them and check their condition...but do we really want to go back that route?
__________________
2007 Lariat screw - White Sand Tri Coat - chrome package - Black leather captains chairs - sunroof - audiophile - 20" Mark LT wheels - Color Matched Door handles -
2005 XLT scab -
1995 xlt scab - 13 inches of lift - SAS
Needed: 2004-2008 OEM cat back for F-150 supercrew
Tags
09 , 2008 , 2009 , 92 , dipstick , dipsticks , escort , f150 , ford , gt , location , tranny , transmission , transmissions , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
