i have a'79 1/2 ton 4x4 with an auto trans that has been sitting for a few years i got it running bot it will not go into any gear there is fluid in the pan but none comes out when i crack a cooler line.thanks in advance.
__________________ '79 f-250 7.3 idi,4x4,3.55 gears,4-speed,some rust,lots of fun
probably not enough trans fluid. try adding some. if still a no go, probably the pump.
__________________
Trey, aka Stretch, aka Slim, aka Shorty, aka Seven-Footer, aka Daddy Longlegs.
'91 F250 red long box super cab w/ 460, 5 speed, 4x4.
'76 F100 tan custom single cab short bed w/ 360, 4 speed, NP205 4x4.
'78 F150 white single cab long bed w/ 400, C6, NP205 4x4. Imagine what I could do if I had all my brain cells.
i cant say for certain, but i think it may not even show up when you dont run the vehicle. you should run the motor, work through all the gear positions, and check the fluid with the motor running in either park or neutral.
__________________
