Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-13-2009, 08:10 PM
dino360 dino360 is offline
dino360 is starting off with a positive reputation.
1991 Ranger clutch master cylinder or slave cylinder?
My '91 ranger has a 5 speed transmision (Mitsubishi I believe) and I now have no clutch pedal. I'm not sure if it's the slave or the master cylinder that's faulty. I do know that for the last few months I have been having to add a little fluid to it about every week or so when I lose pedal but I don't see any obvious leaks. I now have to start the truck in gear bacause I can't get it in gear whith the engine running and the truck pulls forward as I'm cranking it over. It was driving fine yesterday and now all of the sudden today I noticed the pedal was very weak so I added fluid but this did not help. I need to know if I should replace the master cylinder or slave cylinder but not sure how to test either. Thanks for any help I can get.
  #2 (permalink)
Old 10-14-2009, 12:13 AM
rebocardo rebocardo is offline
rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold
Most likely it is the slave or the plastic tubing itself where it attaches to the slave.
You might need a new clutch disc. I have noticed that once the clutch disc becomes almost metal to metal, it seems to take out the slave cyl.
__________________
The Year 2009 Anno Domini -
May it bring a great year of Revelations to you.
  #3 (permalink)
Old 10-20-2009, 01:07 AM
Turns out it was the master cyilinder gone bad. It wasnt leaking but just wasn't making any presure due to contaminated fluid. A mechanic told me that a litle bit of a fluid called trans X would stop the leak in the system. Maybe it did but also ruined the master cylinder.
  #4 (permalink)
Old 10-22-2009, 02:09 AM
Well, at least it is easier to change then the slave. Yea, those stop leak products, of all sorts, create more problems then they solve, especially on hydraulic items.
__________________
Tags
1991 , 1996 , 2003 , bleed , change , cluch , clutch , cylinder , f150 , ford , master , ranger , slave , specs , tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
