Intake ?'s Dove CJ SCJ Boss?
Got a mod-bogger project in the works and I am putting a set of dove-c heads (have been 2.25/1.75'ed allready) on an old Dive block and want to remain in the stock class (external stock).
What stock intake manifolds will fit on my heads? (CJ, SCJ, Boss) Do they have different ports (oval , round)? What's the best bang for my limited buck?
A buddy has some cat iron exhaust manifolds that are real header-looking with individual tubes almost schwoopin' back - look like just the ticket.
But the intake question is where I am at now... I am gonna ask some cam/carb/manifold questions in a month or two.
THANKS!!!
THANKS!!!
What make them in-compatible?
Is it port size?
Is it a small enough diff so some port work on the heads would help?
How do I get some decent flow without going to an aftermarket intake? - which throws me out of a pure stock class - then I might as well follow everyone else and do the three allowed mods, (usually intake, carb, headers)
Is it port size?
It's a 600, I think. What's wrong with Holley?? A Holley carb is stock on the 460. The only use I've found for a Q-Jet is as a door stop on my garage
There is a HUGE mismatch in port sizes which ford got away with becuase they weren't looking for all out HP on those industrial engines and had a bunch of left over intakes they needed to use.
the ports not only aren't the same size they are actually offset slightly too, you can hog the heads out close (but not completely) but it takes a LOT of work.
crucialprospect
09-07-2016 03:05 PM
FossenRacing
12-04-2011 07:24 PM
wd13
02-25-2010 05:00 PM
maxtor
36
11-02-2008 01:46 PM
