ok everyone i went to my local stealership right after work and got the recall preformed
luckily i know the parts guy the mechanic that worked on my truck and the service manager so i have no issues
i made sure they all knew not to touch anything but the recalled part and i advised them before they even opened the hood that the switch would be leaking ... service manager askes in her words " what do u know that i dont"
well i explained that i wanted the whole switch replaced not just a fuseable link and she looked up the diffrence between a leaking switch and a non leaking one and was surprised that i was right AGAIN
I have noticed some break fluid on my floor mat under the break cylinder. Is this from the switch in the recall, or is this just some thing I need to fix? Not at all happy to have a stealership touch my truck.
__________________
Terry PAA # 92
2001 F-250 4x4 Lariat CC SB Front leveler, 315's, Garrett GTP38R w/ ceramic coating, I H Up-pipes ceramic coated, Air Dog II, Ford AIS Intake, Zoodad, Hutch, Harpoon, Banks 4" intake/exhaust w/ high flow muffler, Isspro Boost - Trans Temp - EGT, DP-Tuner F-6 Stock - 80t - 60e - 80e - 120race, A/C valve, 203* thermostat Billet housing, RDP AIH Delete, RDP I C Boots, RDP CCV, RDP Frx, Retrax bed cover, Bedrug,
I work at a dealership and if you take your truck in they will do any and all open recalls on the vehicle. You can however request certain recalls to not be peformed.
The speed control recall does not require any reflash or update to the PCM so don't worry about that.
Any specific questions you guys have I will be more than happy to answer.
I will also run an Oasis for anyone to see what, if any, open recalls there are on their vehicle.
Very nice of you to offer. Thank You
__________________
Jim
2001 F350 4X4 DRW
Bilsteins, 4" Turbo Back Into 6" Stacks, 6637 w/,Custom Cold Air Intake ,Autometer guages, DP TUNER http://www.roadsidehelpnetwork.info/
PAA # 14 RIP Mark.. I'll never forget you!!
I know some dealerships can be pretty shady about the reflash stuff so I probably shouldn't have said that they won't be doing anything like that with this latest recall, after all you know what you do when you ASSume things!
We are pretty honest at our dealership and don't do any updates or work that isn't requested and sometimes I like to think that all dealerships are like that but as we all know that is more dream than reality.
__________________
2000 F350 Crew Cab 4x4 - AIS intake and not much else. . . .YET!
Took my truck to dealership this morning and was told my truck did not have a recall. Tried to tell them what I read on the FORD RECALL site and was still told my truck was not listed. So went to parts counter and they showed me the recall and my truck was listed, told the parts man what the service rep told me and he said he would sell me the fix part for $10. Go figure.
Wish you guys were local to me. Ever since my local dealership let my long time parts guy go, it's been a disaster trying to deal with them.
Stewart
__________________ The Brotherhood of FTE <~click the link 1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft 2002 PSD F250 SC 4x2: 38R, AC codes, MBRP 4", AFE, JWVB, Riffraff HPX, CCV, and boots, ITP OBA, Live Tuned by Jody 2000 PSD Excursion 4x4: John Wood 4R100, F5, MBRP 4", AFE, BDP 1.0, ITP OBA and Pre-Pump mod, V & B code springs, Hellwig rear sway
Do you mind running one on this 01 7.3 Ex. Vin 1FMNU42F41EA09447
Is it normal for the CPS to have oil on it when you pull it? I swapped a gray one in tonight and when I pulled the black one out, there was some oil on the end of it (not the o-ring). Also put two padlocks on the data jack under the dash. Think they'll get the hint?? It goes in for the recall at 8am.
__________________
Trevor
01 F-350 CC 8ft bed SRW 7.3L a/t. 152k
PAA Member #7
Just got back from the dealer. It took all of 20 minutes for them to check the CPS, install the harness and do one of those complementary checks. They did a nice job installing the harness. It would look like its always been there if everything else wasn't covered in dirt. So you guys know, Gilboy Ford in Whitehall PA seems like a decent dealer. They already had 5 people in when I got there, and that was 10 minutes before the shop opened!
__________________
Trevor
PAA Member #7
