Any diesel engine won't properly heat up @ 650 RPM's, if You idle the engine @ 1200 You'll get the engine warm in a few mins.
I've given that some thought and I was hoping I could come up with what the big rigs have where you can set the cruise control while parked and idle the engine at whatever speed you want. Anyone know how the cruise control module can be fooled into thinking the truck is moving so this could be done? I dont even know where the module is and it doesn't work anyway so I'd have some additional figuring to do...
__________________ 2nd Amendment: protector of the rest!!! 2002 Dakota 4.7L-demoted-108k miles 1992 F-350 4X4 7.3L IDI E4OD 4:10LS -124k miles daily driver 1978 F-150 4X4 4spd 351 Holley 600/Edelbrock P-400 (work in progress)
An old solenoid from a carb set at the right length would work.
I think they called it a fast idle solenoid.
You would just flip the switch on the dash and it would push or pull the throttle lever enough to do it.
Mount it near the FIPL.
__________________
Gray 1991 F250 standard cab, 7.3, E4OD, 3.55:1, stock wheels and tires.
Verified 19 mpg city taking off slow as hell the shutting down at red lights, and with the radiator grill blocked flush, no bed cover, "drag shoot" mirrors on I get 24 mpg at 50 to 55 mph on the freeway empty!
However, with a bed cover, no mirrors and Hydroxy
I bought the 1500 Watt unit for my '65 F350 with a gas burner. And yes, they are the Zerostart brand. Last two winter's i have left it plugged in overnight. The next morning is instant heat. Just turn the key to accessory and hit the fan motor and you get hit with heat. I liked the concept of having the water cycle rather than have the heat in a concentrated area. I'm going to be buying another one pretty quick for my 6.9...don't want to crack my early 6.9 block! Install was straight-forward and simple. 2 hours gave good results.
My neighbor has a few newer International roll-back tow trucks. He just leaves his rigs in neutral, sets the brake, cranks his accelerator enough for the hydraulics to run quick, and sets his cruise control.
__________________
1965 F-350 - 352 FE, NP435, Dana 70, Wood Flatbed - Sheet metal soon to be resting on an '85 F350 6.9/T19 Chassis
1985 F-350, 6.9 Diesel IDI, T-19, 2wd 3.55 Dana 70-u (yuck), Chassis candidate for detachable body system, Bought from original owner - young at 95k miles
but could anyone give me a website or store that sells these outdoor extension cords with the timers, i dont know if you have to buy a timer seperately or are they built in. im worried in the winter time when it gets real cold i dont want the electric bill going sky high leaving the truck plugged in all night. im a first time owner of a f-250 7.3L diesel 2000 and would love some answers. thanks
Just get a cheap water heater timer and add either the primary extension cord, or an outlet box to it.
__________________
You could wire the fast idle solenoid for manual control, just supply 12 volts to the terminal on it with a manual switch.
If you do go this route, you should put a diode in between the fast idle and timing solenoids. This way when you toggle a switch to idle up, your not also changing the timing. Not good with drawing pictures or schematics. Maybe someone that is can post what I mean.
__________________
87 CCD, 6.9 Banks Sidewinder turbo & ARP studs, fresh pump & injectors, str8 Pipe out the side, worked C-6, 4.56R&P & Laycock/GearVendors Overdrive
It's all layed out over at OBN
__________________
93 F One Fiddy- 5.0/AOD/3.55 230K OEM
93 F Two Fiddy Scab- 7.3/ZF5/3.55/Sidewinder II,94 Turbo pump,G Inj's, Velvet Ride, Ride Rite Rear, Turbo Bumper, Alcoa's
85 F Two Fiddy-6.9/C6/3.54/ Holley Red, Racor, Soup Bowl,AutoJet 3",Ride Rite Rear
