96 Explorer codes po171 po174 - Ford Truck Enthusiasts Forums
Old 10-13-2009, 06:10 PM
farmnfly farmnfly is offline
farmnfly is gaining momentum as a positive member of FTE.farmnfly is gaining momentum as a positive member of FTE.
I trying to help a freind, his 96 V8 Explorer is running like crap and getting terible gas mileage, he had it scanned at AutoZone and the po171 and 174 codes came up. Looking for a place to start. Thanks
Old 10-13-2009, 11:44 PM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
When was the last Tune-up performed??
PO171 system too lean (bank one) and
PO174 system too lean (bank two)
Clean your MAF sensor with a cleaner that will not leave a residue, change the air filter.
Reset CEL.
If this does not cure the problem look for unmetered air in the intake manifold, Vacuum leaks.
po 171, po 174, po 455 toddrochester Explorer, Sport Trac, Mountaineer & Aviator 3 10-30-2011 07:45 AM
Check engine light on. bowtiebob Explorer, Sport Trac, Mountaineer & Aviator 2 06-21-2010 07:45 AM
Failed inspection 3.8 02 Windstar tomrooster-1 3.8 & 4.2L V6 2 07-01-2009 07:33 PM
2001 Explorer, Codes PO171 and PO174 mileshuff Explorer, Sport Trac, Mountaineer & Aviator 2 04-19-2006 07:22 AM
PO 171 and PO 174 DTC Codes PLatreille 1997-2006 Expedition & Navigator 9 02-13-2005 01:11 PM
Tags
174, 2, 96, 97, bank, code, codes, codespo171po174, explor, explorer, f150, ford, lean, po171, po174, system, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
