Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 10-29-2009, 03:20 PM
rlh68050's Avatar
rlh68050 rlh68050 is offline
rlh68050 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by 01 EXCURSION MORRIS View Post
Thanks for the info.
I will go with the Warn's.
Having a problem with correct part#
Warn states# 28890 (premium)
Some web sites state# 38826
Do you know correct part#
Were did you purchase from. Cost? getting ranges from $229 to $296.Seem to be out of stock though. Warn is at this point in time
Thanks
IMO, Mile Marker are superior to Warn hubs and are less expensive. I have had them on my Ex for 2+ years with zero issues. Summit Racing has them for $155 -> Mile Marker 449SS - Mile Marker Supreme Locking Hubs - Overview - SummitRacing.com
__________________
Rob
2001 Excursion
4x4 V10
  #17 (permalink)
Old 10-29-2009, 03:48 PM
01 EXCURSION MORRIS 01 EXCURSION MORRIS is offline
01 EXCURSION MORRIS is starting off with a positive reputation.
thanks
can't beat the price
  #18 (permalink)
Old 11-03-2009, 05:53 PM
Did you need to purchase a conversion kit?
The kit is a smaller nut at the end of the spindle. It replaces the larger nut from the factory.
Allows hub to fit flush and bolt up.
Thanks
  #19 (permalink)
Old 11-04-2009, 07:22 AM
rlh68050's Avatar
Thanks
No, no conversion kit needed. You may want to use the factory retainer rings (you'll see when you remove the OE hubs) instead of the ones Mile Marker provides. You just need to clip off the 90 deg. bends at the ends.
__________________
Rob
2001 Excursion
4x4 V10
  #20 (permalink)
Old 11-23-2009, 07:59 AM
THANKS FOR ALL THE HELP.
THE MILE MARKERS WERE ON BACK ORDER, SO IT TOOK A WHILE TO GET.
IT TOOK ABOUT 45 MIN TO INSTALL INCLUDING CAPING THE VAC. LINES.
THEY WORK GREAT.
THANKS AGAIN.
Tags
2000 , 4x4 , excursion , ford , hubs , leave , mud , mudding , photo , pvh , quotes , solenoid , stuck , trucks , valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
