Rim size .....how to determine???
most of the standard length came with 14 x 5.5 JJ steel rims unless it came with optional wheels
most of the extended length vans came with 14 x 6.0 JJ
will be stamped into the steel of the rim.
the rim width is important to match since it affects the roll over of the tires.
most tire shops don't like the narrow rims on the Aerostar, either 5.5 or 6"
also match the offset, 115mm from what i remember
doug70
09-16-2010 12:03 PM
doug70
07-23-2010 02:10 PM
