Fuel Pump Replacement
Old 10-28-2009, 10:27 PM
mattop's Avatar
mattop
mattop is offline
Well it looks like on Monday I'll be tackling the fuel pump with a friend of mine. To be prepared, I'd like to have six new bed bolts on hand in case all six need to be cut off. What size, length, and rating should I get?
  #32
Old 10-29-2009, 06:58 AM
subford's Avatar
subford
subford is offline
I just went to my Ford dealers parts department and ask for bed bolts for my 95 and they had them. You will not find them any where else as they are a special bolt. Kind of a flat neck (they are not square). I have not put them in yet but it is raining right now and they are in the center console of my 95. If you want the thread size and the length and a photo I can get it later when it stops raining.
  #33
Old 11-02-2009, 10:26 AM
mattop's Avatar
mattop
mattop is offline
One more question...
I called Autozone to get a price quote on the fuel pump and sender, which they said would be $189.99 (much cheaper than Advance), and they asked me if it was a two tube or a three tube, which I do not know the answer to. Does anyone know if my rear steel tank on a 1996 F-250 is two or three tubes?
Thanks,
Matt
  #34
Old 11-02-2009, 12:53 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,164 Likes on 919 Posts
FWIW my '92 F350 w/351W has a 2 tube FDM. I replaced the rear tank a few months ago. I dropped the tank using short tie down straps as "mini wenches". Worked like a charm.
Matt_S
01-30-2010 07:55 AM
dungeonx
03-14-2007 10:48 AM
Matts72
15
09-15-2003 08:35 PM
Beast12
1983 - 2012 Ranger & B-Series
08-26-2003 05:36 AM
Matt Nalley
02-17-2003 06:39 PM
Quick Reply: Fuel Pump Replacement
