Just a thought or question about “double” overdrive
One of my vehicles is 2000 F-250 with 7.3L that is mostly driven with no load on it, but I like it because of the power and reliability. One of the thoughts I have is this: if I drive my truck unloaded with all this power under the hood, why not add an extra speed (double overdrive) to save some fuel while driving on a freeway? Any one has done it? Is it even possible? Is there anything like that on the market? Not my next weekend project, but this thought is not leaving my had.
__________________
Vitaliy - legal immigrant, naturalized citizen and call it home.
Sacramento, CA
99 Ford F-450 7.3L TD with over 400K and still drives. BEST vehicle ever owned.
2000 Ford F-250 7.3L
2003 Ford F-550 6.0L with 165K miles and most problems. HELP!!!
__________________
Sacramento, CA
I have a Gear Vendors OD in my 92' 1T Chevy. Works pretty slick as the truck has low gears in it. Pulls great and I can still run low RPM on the highway. The previous owner installed the unit for towing a very heavy trailer, he wanted to have the ability to split gears. I have been thinking about seeing if I could install the unit in my Ex as I very rarely drive the Chevy. 1600RPM at 75 MPH would be sweet with a PSD!
not really sure if the trans input would deal with the torque @ 1600 doing 75 mph.
__________________
2000 PSD CC LOOOOOng bed 6spd for the next 20 years (or more) AKA Oklahoma stretch limo
86/87/88 Ranger 2.9 XLT (same truck long story) 88 ranger 2.9 4X4 lifted 20 some inches (parts car)
2003 FOCUS 2.3 5 spd (her car)
4 lines all 2pt.
Give gear vendors a call and they will sell you any adapters you need, in order to make the change from vehicle to the other.
Why is that not a problem Mark? Could someone explain this in a little more detail. I.E. over/under drive, double overdrive, etc.
The overdrive unit attaches behind the transmission, not in front, so nothing changes about the input shaft. The amount of torque at the input shaft at 1600 RPM doesn't change no matter your rear overall geaing, only the engine affects that.
__________________ -Chris
2001 F-350 crew dually 7.3L, Custom CAI using AEM Dryflow, other things, stock tranny and bearings, 186,000 miles. 1994 Dodge Stealth Twin Turbo, definatly not stock. Roadcourse is where it's at. 2002 Honda CBR600 F4i, Yoshi slip-on, geared, undertail, screen, n-more, FOR SALE.
i was also considering doing this to mine but with the price of the overdrive i desided against it unless i can find a used one or a good deal somewhere
I've installed both Gear Vendors and US Gear overdrives and both have their positive and negative points. I personally like the G/V units as they are smaller and lighter, easy to set up, and function basically as a mini automatic transmission.
The biggest downside on the G/V units is the fact that they don't handle negative torque input (deceleration) very well. If you are heavily loaded and use an exhaust brake, you run a good chance of burning up the friction clutch on the gearset.
If you plan to do some serious hauling and use an exhaust brake, the US Gear set seems to be the better option.
Hope this helps.
__________________
Bill Cohron - (678) 963-9913
Calibration Engineer
Occasional DJ
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
