unless GearVendor has changed something drasticly in the last 2 years they will not go between the tranny and T/case. they mount strictly behind and work only in 2WD. US Gear on the other hand mounts between the tranny and T/case and can be used in 2 or 4WD.
Barney
I couldnt remember if it was the usgear or the gv that went between the trans and xfer, Id rather have the usgear anyway I think, even though id have to replace my driveshafts. I like the idea of not having to worry about a worker of mine messing with the o/d button and exploding the driveline of the truck.
__________________
JR Strout...aim UNTAMND...2000 F350 4door-LB 4x4 DIESEL auto, SS HPX, 4" exh, WW, underdash gauges, BLUE dash illumination, AIH Delete, CCV to the rear, FORD apcm Idle controller, airaid dropin w/modified airbox...LOTS and LOTS of tools in the back__Lots of parts not yet installed Coolant filter 6liter transcooler external trans filter sonnex/springs
67 Mustang GTA Fastback 390dual-quad c6...not stock www.UNTAMND.com
91 Geo Metro TURBO 3cyl, large fmic, large turbo, tiny tires...and Yes, its fast!
That's some very impressive numbers for a truck that has 4.88 gears!
Engine is always turning 2500 rpm.
I can impress you even more. That truck is a tow truck, and was driven by employees that drove it like they stoll it, more then that, as a tow truck, we were always pulling load with it from little car to SUV and small motor homes, so it had anywhere from 2.5k lbs to 6k+ behind it at all times. I love that truck. Would like to replace it because of the age, but after my experience with 6.0 just scared to get anything new.
__________________
Vitaliy - legal immigrant, naturalized citizen and call it home.
Sacramento, CA
99 Ford F-450 7.3L TD with over 400K and still drives. BEST vehicle ever owned.
2000 Ford F-250 7.3L
2003 Ford F-550 6.0L with 165K miles and most problems. HELP!!!
The GV WILL work w/ a 4x4, you just have to turn the unit off electronically. Think about it, who in the hell needs O/D or to split gears in 4wd anyway????
Someone correct me if I'm wrong, but the US Gear, being a mechanical unit, has to be controlled mechanically to be shifted in and out of O/D, and when the shift is made you have to let up off the gas to do it? No thanks, I'm trying to make my drive easier, not harder. BUT...if you are full time hauler, in and out of mountains and such, the US Gear seems to be the tougher unit.
Also, noone has mentioned the less revolutions your engine and tranny have to turn...ie, traveling the same mileage, but not really putting the wear and tear on drivetrain.
Jay, I've used the US Gear in 4x4 alot. winter roads, off roading, etc. I like the option of splitting any gear to keep my RPM's wear I want them. Real handy when 4LOW is just too low and 4High is not low enough. Think about it like this, now you can add 22% to any gear combo you choose. I've even used it in reverse, just cause I could.
The US Gear is an electricaly shifted mechanical unit. little servo motor moves the shift fork. If you don't want to shift it up and down, leave it in high or low. If you want to split gears, flip the switch--count to two--feather the throttle--and its done. Not that tough. I think even a Duramax driver could do it!
It does drop the RPM's about 700. so that's definitely an advantage.
with my 4:88s I can cruise at 65mph and only turn 2000 RPM. before I was over 2700!!
Barney
__________________
Live life like a dog...... If you can't eat it or screw it, piss on it!!!
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
