Should I buy the 1998 Bifuel F150
Old 10-12-2009, 09:30 PM
azotos's Avatar
azotos
azotos is offline
I am thinking about buying a 1998 F150 bifuel that was owned by the county. It has the tanks still but it looks like the dashboard switch has been taken out. Should I replace it or should I not even buy the truck. Can I remove the propane tanks and anything that goes with it? Please comment.
Old 10-14-2009, 09:58 AM
jimandmandy's Avatar
jimandmandy
jimandmandy is offline
Are you sure its propane, and not CNG? I understand the valve at the other end of that missing switch is a $1000 part, which may be why it was disabled.
Jim
Old 10-17-2009, 08:48 AM
fraso's Avatar
fraso
fraso is offline
If your truck has an OEM propane (or CNG) system, the alternative fuel system may be disabled because of the problematic Compuvalve. This is an expensive item to repair and there is no guarantee that the repair will be any more reliable than the original part.
The best repair would be to reflash the PCM to a standard gasoline system and use a good aftermarket injection conversion (like Technocarb's ESIP). Since the truck is already equipped with a LPG (or CNG) tank, a major expense in a conversion is already paid for. When gasoline prices start to rise again, you will appreciate the ability to switch to a cheaper fuel.
Once you find out whether it is LPG or CNG, check around to see the going price locally. If you're in UT (for example), CNG is going for around $1/gallon GGE.
bsparks72
Bio-diesel, Propane & Alternative Diesel Engine Fuels
01-06-2020 09:34 AM
chrismcfreely
Engine Swaps
08-30-2019 12:05 AM
bolddane
New Member Introductions
06-09-2017 01:01 PM
chrismcfreely
1997 - 2003 F150
10-23-2015 02:06 PM
wabashtx
Modular V10 (6.8l)
09-01-2005 12:57 PM
Quick Reply: Should I buy the 1998 Bifuel F150
