Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids and Mileage
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Alternative Fuels, Hybrids and Mileage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-12-2009, 10:30 PM
azotos azotos is offline
azotos is starting off with a positive reputation.
Should I buy the 1998 Bifuel F150
I am thinking about buying a 1998 F150 bifuel that was owned by the county. It has the tanks still but it looks like the dashboard switch has been taken out. Should I replace it or should I not even buy the truck. Can I remove the propane tanks and anything that goes with it? Please comment.
  #2 (permalink)
Old 10-14-2009, 10:58 AM
jimandmandy jimandmandy is offline
jimandmandy has a good reputation on FTE. jimandmandy has a good reputation on FTE. jimandmandy has a good reputation on FTE.
Are you sure its propane, and not CNG? I understand the valve at the other end of that missing switch is a $1000 part, which may be why it was disabled.
Jim
  #3 (permalink)
Old 10-17-2009, 09:48 AM
fraso fraso is offline
fraso is starting off with a positive reputation.
If your truck has an OEM propane (or CNG) system, the alternative fuel system may be disabled because of the problematic Compuvalve. This is an expensive item to repair and there is no guarantee that the repair will be any more reliable than the original part.
The best repair would be to reflash the PCM to a standard gasoline system and use a good aftermarket injection conversion (like Technocarb's ESIP). Since the truck is already equipped with a LPG (or CNG) tank, a major expense in a conversion is already paid for. When gasoline prices start to rise again, you will appreciate the ability to switch to a cheaper fuel.
Once you find out whether it is LPG or CNG, check around to see the going price locally. If you're in UT (for example), CNG is going for around $1/gallon GGE.
Tags
1999 , bi , compuvalve , f150 , ford , fuel , make , replacement , technocarb , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
