223 carb problems... Help me out!!
Hey all,
I've got a 223 in my 62 F100. I tried looking for help in the 61-66 forum, but no luck. The 223 was more of the older series anyway! So, I've got a couple issues I can't figure out. The truck began running poorly about a month ago, like it was starving for fuel. I pulled off the road to check it out and it never restarted. I finally dove into it yesterday. It started right up from where I had parked it, but ran pretty badly. It definitely seemed to be a fuel problem, I could smell raw gasoline, but there was no apparent leak. I pulled the oil bath and got the truck to start. It ran for a few seconds before a fountain of gasoline began flowing out of the tube at the top of the carb which stalled and flooded the engine. I then went ahead and rebuilt the carburetor and replaced the fuel pump. It starts right up and runs smoothly but still has the same problem, runs for a few seconds then the fountain of gas starts flowing right down the barrel till it stalls.
What am I missing here? The carb was professionally rebuilt about a year ago and all the gaskets and rubber parts looked fine when I rebuilt it today. Whats happening?
Thanks in advance for the help, I sure need it! Its a daily driver after all
It sounds as if you have loose debris (rust?) in the fuel system that's causing the float to stick. The "fountain of gas" you describe is symptomatic of fuel overflowing past the needle valve. Another possible cause would be fuel overpressure but you did not mention an electric pump so I'm thinking dirt is contaminating the carburetor. I would take the carburetor apart again (at least open the float bowl) and check for contamination in the bowl and take a good look for contamination in the needle valve. If you find something, you'll need to clean out the fuel system. If there is no fuel filter, it's a good idea to add one.
Lou Manglass
Lou Manglass
Just a W.A.G, but I would think that the float is stuck in the full open(down) position or the needle and seat is bad. The truck would start and run until the float chamber fills up and then the fuel pump would be pumping directly into the engine and flooding it. Someone with a better idea should chime in shortly.
Gil
Gil
Thanks for the quick responses guys! Those ideas sound logical to me, I pulled the float chamber cover off and it's spotless in there. In fact, today when I rebuilt it, the kit included a brand new needle and seat assembly. The float itself seems to be a dense foam material, not hollow and it definitely floats, I checked. Is the needle and seat assembly the only suspect? Where is the origin point of that tube at the top of the barrel? Once the fuel flow starts a few seconds after it's running, it flows like a drinking fountain until the engine stalls. I must be missing something. Oh, and there were no extra pieces after the carb rebuild!
There are two settings for the float; how far it drops when the bowl is empty, and the level at which it shuts off fuel. If you don't set the drop correctly, the needle can come down so far it gets jammed and holds the float down, flooding results. When you assemble the carb the bowl is undoubtedly empty, right?
Are you running a stock fuel pump or electric? Could also be pressure-related.
Well, I've got a new stock replacement pump that I installed today, just a rebuilt unit. I've pulled the bowl cover several times now and tried a bunch of different settings for the float but no changes at all. The only difference was when I forced the needle closed, the overflow stopped, but it barely ran and the bowl was nearly empty afterward. I guess that tells me the needle and seat are working properly, as they didn't allow fuel into the bowl, right?
I guess its possible that the float itself isn't working, or maybe the outer bowl cover is physically contacting it, not allowing it to pivot properly. Where can I get a replacement float? All my local parts stores are a no go.
There is a seal washer on both sides of where the needle seat assy mounts. It is easy to have a leak there and the fuel can leak intro ther bowl without flowing through the needle assy. Check it closely.
The tube that the gas is flowing out of is a bowl vent designed to do exactly what it's doing. It does sound like it could be a float since you had the problem prior to the rebuild. A float might be available through Dennis Carpenter or "Number Dummy" might come up with something from an obsolete source. A nitrofil float will absorb water and becomes to heavy to work properly. I've always had to replace for that problem although some claim to have successfully dried them out. I never asked which carburetor it has but it still sounds like a float/needle valve problem that you just haven't pinned down yet. The installation/adjustment is very delicate and very specific, you might run through the procedure again following the rebuild kit instructions. Make sure the clip for the needle valve is positioned correctly around the float arm, the float is set per specs with a accurate gauge or the gauge in the rebuild kit, and even check the float drop as mentioned above. It sounds like you've found the problem but just haven't put your finger on it yet.
Best of luck with it, keep us informed what you find.
Lou Manglass
Lou Manglass
project40
08-07-2014 10:35 PM
JohnBOV43159
53
02-07-2014 11:11 AM
rahnpreston
31
10-14-2013 01:04 PM
