2006 Ranger fuel filter change - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 10-12-2009, 07:53 PM
mldmkr1960's Avatar
mldmkr1960 mldmkr1960 is offline
mldmkr1960 is starting off with a positive reputation.
Question 2006 Ranger fuel filter change
Im going to change my fuel filter for the 2nd time now. The first time it went like crap and had a hard time removing the three lines. Matter of fact I dont even know how I did it without screwing it up. I have three different tools for fuel lines yet they dont seem to work with this type. There are two green and one orange band around the ends. What is the right, easiest way and the proper tool for this. It seems the newer rangers are diff than older ones. Its nothing like the ones on my 1997 F150.
Old 10-12-2009, 11:49 PM
g_k50 g_k50 is offline
g_k50 is gaining momentum as a positive member of FTE.g_k50 is gaining momentum as a positive member of FTE.
I used a blue one, to take off the fuel tank connection. Slip it around the pipe push it into the fitting and pull the pipes apart. Push pipes together to reattach
Old 10-13-2009, 05:53 AM
03 Maz B23 03 Maz B23 is offline
03 Maz B23 is gaining momentum as a positive member of FTE.
On my 03 I used a small screwdriver to push in on the top of the horseshoe clips and then push the line toward filter and then pull to release.
Quick connect fuel line at tank won't release PEG 1997 - 2003 F150 5 11-12-2014 01:27 PM
Fuel filter frustration Mikeman Explorer, Sport Trac, Mountaineer & Aviator 4 09-26-2014 08:30 AM
92 Ranger extended cab fuel tank removal is it hard? 1998Ranger25L153CID Ranger & B-Series 4 08-08-2014 11:54 AM
Fuel lines BreeAna Ranger & B-Series 7 07-08-2014 06:04 PM
94 f150 fuel filter fordka 1987 - 1996 F150 & Larger F-Series Trucks 3 06-06-2014 04:37 PM
Tags
04, 06, 2000, 2002, 2005, 2006, change, changing, filter, ford, fuel, located, pump, ranger, replacement, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
