2002 explorer transmission fluid leak (not from trans)
Hi,
I have an '02 explorer that is leaking transmission fluid. It is not coming directly from the tranny :-(
There is a black rubber hose that i believe originates at the transmission and runs up above the exhaust system very close to the bottom of the cab. I'm not sure where it ends up yet. It has a black plastic connection (2-3" long) and it appears to be leaking from this connection. The location is such that it drips right on top of the O2 sensor when sitting still. About 1 drop/minute.
Any idea what the hose is for? I though cooler line but those are usually hard lines. Any suggestions on a repair? There's no clamp on either side. I have not tried to mess with it yet as the exhaust was too hot last night to get up there to work with it.
Thanks
Ron Madurski
Thanks
Ron Madurski
erajkowski
17
06-13-2016 07:56 PM
razor10000
10-03-2015 07:24 AM
John Olson
04-30-2012 09:17 AM
