Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Canadian National Chapter > Alberta Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Alberta Chapter Join Chapter, Leader: Hallworth
  #1 (permalink)
Old 07-09-2002, 05:58 PM
GORSTEP GORSTEP is offline
Garage is empty, add now
GORSTEP is starting off with a positive reputation.
56 mercury?
Howd you make out with head gasket? Did you get your distributor trouble figured out?
__________________
01 C/C dually 2wd, V10 auto, XLT, Harvest Gold Metallic
Gord S
  #2 (permalink)
Old 07-10-2002, 02:04 AM
Burple's Avatar
Burple Burple is offline
1985 Ford F-350
Burple is starting off with a positive reputation.
56 mercury?
__________________
http://groups.msn.com/thetrousertrout
  #3 (permalink)
Old 07-10-2002, 09:56 PM
56mercury 56mercury is offline
56mercury is starting off with a positive reputation.
56 mercury?
Hi GORSTEP, sorry to take so long to reply but contending with home duties shift work and gathering the parts and stuff to change out the heads and gasket on the 56. Plan on attacking this project possibly tomorrow afternoon. Have decided to go back to the 2v heads so i don't have problems with the mixing of gas for this mill. Will be able to run more ignition timing and have better torque and response for the street. Am finding that i am less and less inclined to make the time to "fiddle" with the hi per motors. Would rather run a more stock setup and go anywhere anytime. Thanks for asking and will keep posted. Certainly plan to have it at the Lacombe show and possibly have a swap table set up. Reminds me that i need to call about that. Later, pops
__________________
luv 'em lo and slo, but they gotta be able to go!! The Old Ford Man
  #4 (permalink)
Old 07-14-2002, 10:02 AM
56 mercury?
I know what you meen! Me too. Good luck with the repairs.
__________________
Gord S
  #5 (permalink)
Old 07-16-2002, 02:16 PM
phat56's Avatar
phat56 phat56 is offline
phat56 is starting off with a positive reputation.
56 mercury?
Hey Pops - I plan on taking in Lacombe as well -what time do you think you'll get there? we could dominate the show with the ultimate trucks Bill
__________________
Bill - '56 F100, '65 F100
  #6 (permalink)
Old 07-19-2002, 09:53 PM
56 mercury?
Hey Guys, thanks for the interest in my quandry with the Merc.
Latest poop, got fed up with the engine not running like it should and not responding to ANY change that should have made an improvement.
Pulled the intake and 4v heads from it this past Tues and lo and behold, there is the problem!!!! Intake gasket on #4 and #6 runners have leak from the lifter valley into the intake runners!! #4 was the worst but 6 was also oily in the head runner to the valve. When i pulled the exhaust manifolds both of them were oily and black. It wasn't pulling enough to create smoke from the exhaust but sure caused a bunch of grief trying to get it timed and running well. Have not seen this before. When the engine was built i didn't use any sealant on the intake gaskets (never have on other engines before, either) but will probably start doing this now. Presently am in process of installing 2v heads with 4v manifold. This will allow me to run pump gas and not worry about detonation as much. Will also give better response in the bottom end of the rpm range.(i hope)
As for the Lacombe Days, will try to get up there but won't likely have the 56 there and also won't have a swap table.( went looking and found that i don't have as much around as i thot) Need to get out and do some more treasure hunting. Later pops
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
