OK, I did the first Oil change on my truck and I discovered that the oil filter was not the normal Motorcraft filter, but some other brand that had NO mention of Ford or Motorcraft on it. If that was not bad enough it was put on by a gorilla and a PITA to get off. I am just wondering if anyone else has noticed this?
Have read & heard a lot about this issue recently and I will soon find out for myself, as my 09 will soon get its first oil change. Gonna take it to the dealer since the first change is FREE, and let them deal with it. After that, I will always do my own changes
what you seen is normal, from the factory the only marking is a black square( cost saveings i guess) deales get ones with red squares or motorcraft on the side
and their hard to get off new, factory install at 25 ft lbs dry
Factory install on left, Motorcraft FL-820S on right in both shots.
Note the number of flutes on factory as others have mentioned. The Moto FL-820S has 36, so if you bought the tool you would only be able to use on your new filters not the original. Both are the same dia. though. BTW, I think the factory original may be made by Champion, but still looking into that to confirm. Not Motorcraft for sure.
I wonder if Ford is changing vendors for filters again. The one that came on the truck originally looked like it could have been a Fram or Wix or something.
I think it is the kind of item that may have different sources/vendors at different times. It is a standard ubiquitous part that can be had from many places, depending on price etc etc.
