Airbag light / seatbelt sensor
Most probably a bad connection. The wires are pretty easily tangled in a rear seat passengers feet if they stick them under the front seat.There's a sensor to tell if the seat belt is buckled but it won't affect the SRS. The wiring for the seat belt tensioner will set off the light. The AIR BAG light should blink a 2 digit code upon start-up. Count the blinks and post here.
03 F150 SUPERCREW
I've got an 03 F150 SuperCrew that is giving me an airbag code 46. The truck was in an accident, both bags were blown. I've repaired the truck and replaced the bags and module (it was previously giving me a code 19 before I replaced the module).
I've had trucks that had pretensioners blown, but the supercrew doesn't seem to have pretensioners. Are they in the seatbelt on a supercrew instead of the buckle? If not, what else could be causing the code 46?
thnx.
thnx.
Haven't been in a Super Crew in a while. Are your seat belts/retractors integral to the seats or in the door posts? If your seat belt retracts into your seat then the pretensioner is in the buckle. If your seat belt retracts into the door post then the pretensioner is in the retractor, in the door post.
If you replaced the bags and not the pretensioners then that's your issue. If it blows the bags it blows the belts!
Safety Belt Pretensioners
As part of the supplemental restraint system (SRS), the vehicle is equipped with one of two types of safety belt pretensioners. The pretensioners are activated by the restraints control module (RCM) when the module detects a crash event force exceeding a programmed limit.
Safety Belt Retractor Pretensioners
Vehicle not equipped with seat integrated restraints (SIR), the safety belt retractors are equipped with pretensioners. The belt retractor pretensioners rotate the safety belt retractors to remove excess slack from the safety belt webbing.
Safety Belt Buckle Pretensioners
Vehicle equipped with seat integrated restraints (SIR), the safety belt buckles are equipped with pretensioners. The safety belt buckle pretensioners remove excess slack from the safety belt webbing.
Passenger Air Bag Deactivation (PAD) Switch
brc777
1983 - 2012 Ranger & B-Series
01-06-2017 02:38 AM
ketel0ne
1999 to 2016 Super Duty
04-15-2014 09:10 PM
