Airbag light / seatbelt sensor - Ford Truck Enthusiasts Forums
Old 10-11-2009, 05:44 PM
briank briank is offline
briank is starting off with a positive reputation.
Have a 2003 Explorer with 70K. The Airbag Light comes on and stays on. Last 2 times this happened Ford said it was the SeatBelt sensor. What would cause the sensor to go bad?
Old 10-11-2009, 06:28 PM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
Most probably a bad connection. The wires are pretty easily tangled in a rear seat passengers feet if they stick them under the front seat.There's a sensor to tell if the seat belt is buckled but it won't affect the SRS. The wiring for the seat belt tensioner will set off the light. The AIR BAG light should blink a 2 digit code upon start-up. Count the blinks and post here.
Old 10-12-2009, 07:11 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
start the truck and look at the light as mentioned. you will get a code like 3 - 3 for 33. It will repeat 3 times, then light stays on constantly. The code tells you if it is driver side, passenger side, under the seat or inside the dash.
Old 11-18-2009, 04:57 PM
cop0251 cop0251 is offline
cop0251 is starting off with a positive reputation.
Air bag light
My 02 F150 the airbag light blinks 4times then 6 times, does anyone know what this code means? Thanks for the help.
Old 11-18-2009, 08:14 PM
ncranchero's Avatar
Old 12-19-2009, 08:18 PM
cdriedger cdriedger is offline
cdriedger is starting off with a positive reputation.
03 F150 SUPERCREW
I've got an 03 F150 SuperCrew that is giving me an airbag code 46. The truck was in an accident, both bags were blown. I've repaired the truck and replaced the bags and module (it was previously giving me a code 19 before I replaced the module).
I've had trucks that had pretensioners blown, but the supercrew doesn't seem to have pretensioners. Are they in the seatbelt on a supercrew instead of the buckle? If not, what else could be causing the code 46?
thnx.
Old 12-19-2009, 08:32 PM
ncranchero's Avatar
Haven't been in a Super Crew in a while. Are your seat belts/retractors integral to the seats or in the door posts? If your seat belt retracts into your seat then the pretensioner is in the buckle. If your seat belt retracts into the door post then the pretensioner is in the retractor, in the door post.
If you replaced the bags and not the pretensioners then that's your issue. If it blows the bags it blows the belts!
Safety Belt Pretensioners
As part of the supplemental restraint system (SRS), the vehicle is equipped with one of two types of safety belt pretensioners. The pretensioners are activated by the restraints control module (RCM) when the module detects a crash event force exceeding a programmed limit.
Safety Belt Retractor Pretensioners
Vehicle not equipped with seat integrated restraints (SIR), the safety belt retractors are equipped with pretensioners. The belt retractor pretensioners rotate the safety belt retractors to remove excess slack from the safety belt webbing.
Safety Belt Buckle Pretensioners
Vehicle equipped with seat integrated restraints (SIR), the safety belt buckles are equipped with pretensioners. The safety belt buckle pretensioners remove excess slack from the safety belt webbing.
Passenger Air Bag Deactivation (PAD) Switch
Old 12-19-2009, 09:24 PM
Just went out and checked, tensioners are definately in the retractors. Are the tensioners part of the seatbelt assembly or can I get them separately?
Thanks for the tips ranchero!
Old 12-19-2009, 09:32 PM
ncranchero's Avatar
You'll have to buy the belt assemblies. Go back to where you bought the bags and see if they don't still have them.
Fast Parts Network, LLC
Are There Any Airbag Sensors on the front of a 2004 Ranger? brc777 Ranger & B-Series 1 01-06-2017 03:38 AM
2008 Airbag and Seatbelt Lights dtherrien 2004 - 2008 F150 0 11-12-2016 05:40 PM
Did the 06 to 03 seat swap, now airbag light issue ketel0ne 1999 to 2016 Super Duty 2 04-15-2014 10:10 PM
Lights - Airbag, ABS and seat belt lights + kbayard 2004 - 2008 F150 9 02-23-2011 08:39 PM
2002 E150 - Seatbelt Warning Light/Sensor malfunction whalerron 1968-2013 Full Size Vans 2 06-08-2010 07:49 AM
Tags
2003, 2006, 2008, air, airbag, bag, belt, codes, econoline, f150, ford, light, seat, sensor, stays, tools, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
