Where to splice prestone flush kit? - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 10-11-2009, 05:07 PM
gschwoyer gschwoyer is offline
gschwoyer is starting off with a positive reputation.
I gotta change my coolant, but didn't realize how bad it really was. Rather than draining and filling several times, I'm considering a prestone flush tee. Where do I splice it in? I'm thinking it gets spliced in the hose adjacent to the oil fill cap. Am I right. Anyone have a pic of their flush kit? Any help is much appreciated.
Old 10-11-2009, 06:05 PM
madsonp's Avatar
madsonp madsonp is offline
madsonp has a good reputation on FTE.madsonp has a good reputation on FTE.madsonp has a good reputation on FTE.
If I remember correctly they say to put it on the heater core inlet line which is to one on the right as it goes through the firewall. I put one on both the inlet and outlet lines so I could back flush through the heater core because I had some blockage in mine.
Old 10-11-2009, 11:06 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
IMO don't install it period. Installing the tee creates a restriction in the heater hose due to the OD of the tee being equal to the ID of the hose. The end result is less coolant flow into the heater core and less heat output from the core.
I always disconnect a heater hose and connect the garden hose directly to it.
Old 10-12-2009, 08:17 AM
Johnny Langton's Avatar
Johnny Langton Johnny Langton is offline
Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.
F150's and Expeditions already have a restrictor in the hose that's smaller than the Prestone kit's adapter. As sensitive as the heater cores are on these vehicles,it's not a bad thing to have an extra restrictor in the heater core inlet to help prevent leaky heater cores.
JL
Coolant compatibility ? TOMMAY Cooling, Heating, Ventilation & A/C 7 03-05-2015 10:55 PM
Quick answers please in coolant High76boy 6.0L Power Stroke Diesel 3 06-08-2014 01:46 AM
WHats the difference? is there any? motorcraft gold vs regular prestone coolant Truckie256 Cooling, Heating, Ventilation & A/C 1 06-02-2014 06:14 AM
03 coolant change flush questions dan_s_johnson Expedition & Navigator 1 11-23-2009 10:30 AM
Coolant flush on a 7.3 turbo IDI csangster Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 09-20-2007 03:19 PM
Tags
2002, 46l, 98, back, core, expedition, f150, flush, flushing, ford, heater, hose, identification, kit, prestone, store, tee
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
