Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-11-2009, 02:53 PM
esebm esebm is offline
esebm is starting off with a positive reputation.
Replace spark plugs
Hi,
I have a '04 6cyl Escape.
How easy/cumbersome is it to replace the spark plugs?
Thanks.
Ed
  #2 (permalink)
Old 10-11-2009, 08:30 PM
bigkat91 bigkat91 is offline
bigkat91 is starting off with a positive reputation.
You have to take the plastic piece off that covers the engine first. Then remove all the hoses and vacuum lines off the upper intake and remove the cruse and throttle cables, unless DBW. Then remove the rubber tube connecting the air filter box to the throttle body. The EGR tube from the catalytic converter has to be unscrewed and then unbolt the upper intake manifold. I think there is six bolts~~.
While you are doing this make sure you replace the pvc valve while this is off.
I made the mistake of not doing it and am going to pay for it later this week.
Also you will need new gaskets for the upper intake.(cheap insurance) here is a guide that i used.
How to Replace Spark Plugs on A V-6 Ford Escape .: Articles
  #3 (permalink)
Old 10-12-2009, 11:48 AM
Wow, that's quite a job.
Thanks for the link.
Ed
  #4 (permalink)
Old 10-12-2009, 02:07 PM
It wasn't that difficult just time consuming. It might help if you have a good helper there too. I think the most difficult part was attaching the egr tube back to the egr valve
  #5 (permalink)
Old 10-12-2009, 08:11 PM
tcesni tcesni is offline
tcesni is new and has a neutral reputation at this point.
Quote:
Originally Posted by esebm View Post
Hi,
Thanks.
Ed
If you do a search of spark plug threads you should find a thread from a couple of years ago that has photos and everything. The job takes a couple of hours but there is nothing difficult, just take your time.
  #6 (permalink)
Old 10-13-2009, 01:55 AM
bmuhlbach bmuhlbach is offline
bmuhlbach is starting off with a positive reputation.
Its not that hard at all just follow the directions i just did it on Friday to replace a coil pack.
__________________
Buy American your job depends on it.
Tags
2001 , 2002 , catalytic , change , coil , converter , escape , f150 , ford , hybrid , pack , plugs , remoce , remove , spark , sparkplugs , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
