ranger rim bolt pattern? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 10-11-2009, 12:33 PM
hotroddually's Avatar
hotroddually hotroddually is offline
hotroddually is gaining momentum as a positive member of FTE.hotroddually is gaining momentum as a positive member of FTE.
i have 2001 ranger xlt supercab 4x4. i was wondering the wheel bolt pattern dimensions on this truck. i am considering buying a second set of tires and rims for the truck,and i was wondering what the bolt pattern size is? do the earlier model year ranger or broncoII rims fit the 2001 ranger 4x4? i have hear that jeep rims are the same bolt pattern too,but im not sure if that is true.
Old 10-12-2009, 06:14 AM
mrford60's Avatar
mrford60 mrford60 is offline
mrford60 is starting off with a positive reputation.
5 on 4 1/2 any year ranger, bronco II or mustang rims will fit
Old 10-12-2009, 12:31 PM
PhoenixRisen PhoenixRisen is offline
PhoenixRisen is starting off with a positive reputation.
Don't put small diameter wheels on there because of the brakes size. But yes, Some Jeep wheels will fit. I have a 2000 Ranger and I've had several wheel combinations on it and it has been lifted and lowered. And yet I am back to stock now. Let me know if you have any other questions about it.
Old 10-12-2009, 12:44 PM
Quote:
i did notice that the older rangers that are 2wd have 14 inch rims. i would stick with at least a 15 inch rim. i want to have a set of tires mounted on rims ,so its an easy swap from off road tires to street run tires. the new rangers can even have a 16 rim on them from the factory. they still look the same style as my 2001 rims,but they are 16 inch. -thanks for replying.
Old 10-12-2009, 10:56 PM
woody1963's Avatar
woody1963 woody1963 is offline
woody1963 is starting off with a positive reputation.
I have a 2000 ranger xlt 4X4. My wheels went on my sons 99 jeep wrangler kinda snug... We had to work at it. But the jeep wheels fit my ranger easily. Must be hub diameter. But 4.5 X 5 is the bolt pattern.
bolt pattern speedracer54729 Ranger & B-Series 2 03-01-2015 11:56 PM
rim bolt pattern Ford or nothin 1997 - 2003 F150 1 08-16-2013 10:09 PM
Will Ranger rims and tires fit in a 1992 Aerostar Sport? geearturi Aerostar 23 01-08-2013 09:58 PM
rims gcptc 1973 - 1979 F-100 & Larger F-Series Trucks 15 03-19-2011 02:24 PM
do all super dutys have the same bolt pattern? rebelbob 1999 to 2016 Super Duty 10 01-14-2009 05:49 PM
Tags
2007, 4x4, 99, bolt, escape, ford, lug, pattern, ranger, rim, size, specs, truck, wheel, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
