Door locks, auto headlights, and dash lights problem - Ford Truck Enthusiasts Forums
Old 10-11-2009, 11:20 AM
HogTied's Avatar
HogTied HogTied is offline
HogTied is starting off with a positive reputation.
Unhappy Door locks, auto headlights, and dash lights problem
Thursday morning when I got into my truck to go to work I smelled a strange electrical smell but didn't think anything of it. Later that day, I tried to unlock my passenger side door with the keyless entry, but it didn't work. I went inside and tried using the button on the driver's door to unlock it, but it didn't work. While I started to take off, I noticed the truck didn't try to automatically lock the doors like it should. I then tried to lock them myself, but it didn't work. The only thing that does work is it will UNLOCK the driver's door. That's it.
Another thing I noticed that stopped working on Thursday is the dash lights when you have the headlights set to AUTO. If you turn them on manually, the dash lights work fine.
Does anybody know what could have happened and if it can be easily fixed?
Old 10-11-2009, 02:18 PM
screwy's Avatar
screwy screwy is offline
screwy has a good reputation on FTE.screwy has a good reputation on FTE.
Sounds like your body control module, and electrical smells are never good. Id start checking fuses.
Old 10-11-2009, 09:58 PM
HogTied's Avatar
What is a body control module?
Old 10-12-2009, 01:46 PM
screwy's Avatar
It’s that lil black box everyone’s always looking for when they’ve lost the code for their door. It’s behind the rear seat in most trucks. It controls the door locks, auto headlights etc.
Old 10-12-2009, 06:11 PM
mlytc mlytc is offline
mlytc is starting off with a positive reputation.
Probably a short in the instrument cluster, just got my wife's 06 expedition out of the shop for the same thing, auto lights wouldn't work, worked fine manually, radio would not turn off with the key removed and the door open, A/C blew but compressor would not cycle to get cold air, interior lights wouldn't come on when you opened the door, etc... The mechanic said he would have bet his paycheck it was the body control module.
Old 10-14-2009, 02:23 AM
HogTied's Avatar
Mine's a single cab 4x4. Where is the box located?
Old 10-15-2009, 07:45 AM
HogTied's Avatar
Old 10-15-2009, 05:53 PM
Oldguy4 Oldguy4 is offline
Oldguy4 is starting off with a positive reputation.
Quote:
No one answered this? I don't know for sure, but can't help but think it would be mounted in the back of the cab just behind the seat back. But I'm worried about that electrical smell you had. That don't sound good right there.
Old 10-15-2009, 10:13 PM
screwy's Avatar
Should still be on the back wall behind the drivers seat.
Old 10-16-2009, 09:12 PM
HogTied's Avatar
Quote:
Must be behind the plastic wall because its not anywhere in sight.
Old 10-18-2009, 11:47 AM
lv2race's Avatar
lv2race lv2race is offline
lv2race is gaining momentum as a positive member of FTE.lv2race is gaining momentum as a positive member of FTE.
I had weird electrical problems with the Expo and read somewhere here that the windshield seal will leak and water will drip on the ECM, which should be located by your left foot under the dash, possibly behind the plastic cover. Have you had rain lately? My windshield was cracked anyway, so I had it replaced and we have not experienced any of the electrical issues since.
Old 10-18-2009, 10:00 PM
HogTied's Avatar
The passenger side floorboard was wet before this all happened.
Old 10-19-2009, 01:57 AM
lv2race's Avatar
Sounds like a windshield leak to me.
Old 10-23-2009, 07:50 AM
HogTied's Avatar
I just need to know what I need to replace to get the door locks and everything else working again.
Old 10-23-2009, 04:16 PM
One thing you can check is to make sure you didn't get moisture in the fuse panel where it started corroding. You might have to disconnect the battery and then pull the fuse panel off its mounting location to see behind it. I've seen posts on here before where water has wicked in from under the hood following the harnes through the fire wall and gotten into the fuse panel. You said you had water on the floor of the passenger side.
2006 power door locks greenheads 1999 to 2016 Super Duty 1 03-16-2015 03:10 PM
Electical problem? kerbking Excursion - King of SUVs 6 05-01-2012 10:35 PM
Need help with weird key fob problem GwarForAll1021 2004 - 2008 F150 2 04-03-2012 02:32 PM
Keyless entry question Kimberguy Excursion - King of SUVs 2 02-09-2012 10:02 PM
Easy fix for 98 Explorer exterior handle springs renee Explorer, Sport Trac, Mountaineer & Aviator 3 07-30-2008 03:51 PM
Tags
2001, 2003, arkansas, control, dashlights, door, door locks, doors, f150, ford, head, headlights, lights, razorbacks, truck, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
