F250 engine in an f150
Old 12-07-2021, 07:47 PM
cmsks09's Avatar
cmsks09
cmsks09 is offline
Hello !
hopefully someone can help me out.
My brother bought a 2008 F150 with no motor (against better judgement) .. he is trying to find an f150 engine for it. In the other hand I could actually use the hauling power of an F250.
Is it at all posible to fit an F250 engine in to an F150?
if so what are the repercussions? Meaning what would also have to be upgraded for the powerful engine to not destroy the rest of the truck?.
let me know what y’all think.
Thanks
Old 12-07-2021, 11:07 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,584 Likes on 1,292 Posts
Welcome to FTE.
You will have better luck in this forum. But you need to provide more information.
What engine was in the 2008 F150? What remains of the wiring and controls? Transmission?
An F250 engine may or may not work, not because of power but because of engine control. Whatever engine you get has to be compatible with the electronics and transmission, if any, in the 2008.
The following users liked this post:
Old 12-08-2021, 02:35 PM
Conanski's Avatar
Conanski
Conanski is online now
Originally Posted by cmsks09
On the other hand I could actually use the hauling power of an F250.
Then you need an F250. An engine alone doesn't make an f150 into a HD truck.
Yes if it's the exact same motor. For example the 4.6 and 5.4 2V engines were used in all trucks, full sized E Series vans still use them to this day so if it's one of those you need these trucks may be a good source.
If so what are the repercussions? Meaning what would also have to be upgraded for the powerful engine to not destroy the rest of the truck?.
You are making bad assumptions about engines, the gas engines found in most HD trucks are less powerful than those found in 1/2 tons... the exception would be a diesel but those are too big and heavy for a 1/2 ton suspension.
The other factor that makes using anything but the same engine the truck came with is that engines and their control systems are very complicated these days. anything is possible but with vehicle security and other systems all being integrated with powertrain control a project like this can get quite expensive and complicated if it's anything beyond a direct plug and play.
Old 12-08-2021, 05:03 PM
97 Mountain Man's Avatar
97 Mountain Man
97 Mountain Man is online now
If his F150 came with a 5.4 it will be a 3 valve, not a 2 valve.
Old 12-08-2021, 07:29 PM
Johnny Paycheck's Avatar
Johnny Paycheck
Johnny Paycheck is offline
Hello !
As we were taught in physics class back in the day, Force = Mass x Acceleration.
A 5.4L Triton engine from a Super Duty will put out the same 300 hp @ 5,000 rpm and 365 lb-ft @ 3,750 rpm. What makes the difference is the extra ~1,000 lbs of weight that kind of truck has that an F150 doesn’t.
So, get more actual truck. That’s your winning ticket.
Even if you made a 6.4 PowerStroke diesel work in that F150, it wouldn’t do much. You lose several hundred lbs of payload and the handling goes to hell.
Old 07-12-2022, 04:34 AM
zoomeroo's Avatar
zoomeroo
zoomeroo is offline
Mounting solenoid
Pull air intake. Plenty of room underneath. Close to up fitter connections.
Old 07-12-2022, 09:54 AM
redfishtd's Avatar
redfishtd
redfishtd is offline
I think the engine is the same 5.4 3v , you may need the wiring harness and ecm that that new motor came from . The van motor is slightly different routing of intakes and that kind of stuff so I would avoid that . You are not going to get a 250 out of that .A used engine is a gamble and they are expensive , think reman .
justkvd
New Member Introductions
01-03-2017 06:49 PM
guitar9999
03-20-2008 12:32 AM
sunman
08-22-2007 07:40 PM
Quick Reply: F250 engine in an f150
