Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered, Classic and Box Style Ford Trucks SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 10-11-2009, 01:10 PM
jim collins jim collins is online now
jimbos / junk
jim collins is starting off with a positive reputation.
Quote:
Originally Posted by rtcalabrojr View Post
Automatic
colume shift
removed starter
No other way to lift just an engine host. This is in my buds garage.
So what do you think now? Thanks!!!
If you haven't done it allready , remove the oil pan and see if you can find what's locking the engine . Could be a broken or bent piston rod . broken crank or rod bearing ,ect. It doesen't take much to lock a engine sometimes . Being it made a loud noise and stopped ,I would suspect internal engine damaged has locked it up . You have went this far so a litle extra work might just find something and it might save you from removing the trans. or damaging the trany by pulling the T C out of it .
__________________
JIMBOS/JUNK
  #17 (permalink)
Old 10-11-2009, 01:56 PM
rtcalabrojr's Avatar
rtcalabrojr rtcalabrojr is offline
rtcalabrojr is starting off with a positive reputation.
thats what we are doing now removal of oil pan.
__________________
Roger
1955 F100
I smell cookies! click to check out the truck
http://s919.photobucket.com/albums/ad37/rtcalabrojr/
  #18 (permalink)
Old 10-11-2009, 02:05 PM
jimbos / junk
A pushrod coming loose could lock engine , you could spot that pretty easy with valve cover removol .
__________________
JIMBOS/JUNK
  #19 (permalink)
Old 10-11-2009, 04:19 PM
heads off and nothing there, crank still wont turn.
__________________
Roger
1955 F100
  #20 (permalink)
Old 10-11-2009, 04:35 PM
mtflat mtflat is online now
mtflat is gaining momentum as a positive member of FTE. mtflat is gaining momentum as a positive member of FTE.
Timing chain break? That would throw the valves out of sync with the crank and "lock" things up.
I'd pull the trans with the engine so you can work on it out in the open. You've got lots of room to spare - I've pulled 3 or 4 302s from 82-92 trucks.
Drop the driveshaft, put the trans in neutral and try turning the engine over. With the heads off and nothing amiss there, the problem's likely in the bottom end - or timing gear.
  #21 (permalink)
jimbos / junk
Did you drop the pan ? take the rod bearing caps of and shove all of the pistons to the top . I dont think you will need to remove them, that should get any load of the crank so it will turn , if you have removed the starter so you know it's not jamed in to the flywheel . good luck
__________________
JIMBOS/JUNK
  #22 (permalink)
Old 10-11-2009, 05:14 PM
jimbos / junk
I hope you have located your problem and I dont want to bring you anymore disapointing news , but it would be best if you can crank the engine to remove the bolts . If you pull the T C out of the trans. attached to engine , I don't believe you can remove the bolts until you crank the engine , do to not being able to get a wrench in there . So you will be out a new housing plate , flywheel flexplate , and new T C . I hope I'm wrong .
__________________
JIMBOS/JUNK
  #23 (permalink)
Old 10-11-2009, 05:26 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has a good reputation on FTE. AXracer has a good reputation on FTE.
If you are going to pull just the engine or engine and TC, be sure to jack or block front of tranny at slight upwards angle and watch gap between engine and bellhousing as it come out. Be sure it stays parallel until the engine is free of the tranny so you don't put undo stress on input shaft. If it were mine I'd pull engine and tranny as unit, much easier that way.
__________________
Passionate about autocross racing!
2003 GSL, 2005 HSL National Champion
1956 F100 Panel support/tow vehicle
2007 Solstice GXP racer, the "KRAZED KANARY"
2002 Celica GT 2003 GSL National Champion retired to daily driving duties
  #24 (permalink)
Old 10-11-2009, 06:18 PM
rbig1 rbig1 is offline
rbig1 is starting off with a positive reputation.
i had a 87 ford van blow had to take timing cover off and take chain off cam was broke in three pieces took out center of block crank turned with clunking had to put pic at photo bucket of c notch http://s572.photobucket.com/albums/ss170/rbig1/
  #25 (permalink)
Old 10-11-2009, 06:39 PM
sdetweil's Avatar
sdetweil sdetweil is offline
1955 Ford F-100
sdetweil is gaining momentum as a positive member of FTE. sdetweil is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by rbig1 View Post
i had a 87 ford van blow had to take timing cover off and take chain off cam was broke in three pieces took out center of block crank turned with clunking had to put pic at photo bucket of c notch Pictures by rbig1 - Photobucket
very nice on the C (aka step) notch!..
Sam
__________________
55 F100 460/c6, 3.55ls
08 F350 4x2, DRW, CC, LB
  #26 (permalink)
Old 10-11-2009, 09:04 PM
Well the crank was cracked!! Yes cracked in two! The second cap from the rear of the block also cracked? We also pulled the motor out with the T>C on it. It was really no big deal. Now to put in the replacment motor. Thanks TO all!!!
__________________
Roger
1955 F100
  #27 (permalink)
Old 10-11-2009, 09:58 PM
sdetweil's Avatar
1955 Ford F-100
and left the tranny in the truck?
Sam
__________________
  #28 (permalink)
Old 10-11-2009, 10:24 PM
Quote:
Sam
yes we did
__________________
Roger
1955 F100
  #29 (permalink)
Old 10-12-2009, 08:29 AM
jimbos / junk
Sorry to hear that , but suspected as much that's the reason I sugested to drop the pan . I new it sounded like bottem end problem . AS you were advised earler , be sure to index the T C in trans. I have problems there as it's easy not to get it far enough in . It will lock engine , could damage pump and I have known of guys breaking the trans. housing when they tighten the housing to engine bolts . I suggest you replace the trans. front seal as it could have got damaged as the T C came out and it's easy to do now. good luck . JIM
__________________
JIMBOS/JUNK
  #30 (permalink)
Old 10-25-2009, 09:30 PM
Ok guys the saga still going! We replaced the trans seal. Installed the motor back in the tuck but cant turn the motor to get to the TC bolts! What the H@$L!! Any info here or tips would be good. If we lossen the bellhouosing bolts, then it turns? When i put my c6 on my 351c i had no problems! It just bolted up! This is a lot more harder just for the fact its all in the truck. Thanks!!
__________________
Roger
1955 F100
Tags
302 , bolts , c6 , converter , engine , flywheel , ford , removal , remove , removing , stuck , torque , tranny , transmission , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
