Electric fuel pump relay location - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 10-11-2009, 07:30 AM
docpec1's Avatar
docpec1 docpec1 is offline
docpec1 is starting off with a positive reputation.
I have tried to find the electric fuel pump relay in my '87 E350 RV. The shop manual says it should be near the drivers side fender well area. My VIN code shows the the RV as an '87 cutaway E350.
Any ideas??? Thanks.
Old 10-11-2009, 09:16 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Should be on the drivers inter fender:
Old 10-19-2009, 06:13 PM
docpec1's Avatar
Thumbs down Where is the fuel pump relay
I have looked all over the fron of the vehicle and can not locate the electric fuel pump relay. This is an E350 cutaway RV chassis. Could the relay be located somewhere other that the engine compartment???
Old 10-19-2009, 07:51 PM
subford's Avatar
Look near the oil filter and see if you have a fuel pump on the side of the engine block.
If you do you do not have a relay.
If you do not have the fuel pump on the side of the engine then there should be two relays for the fuel under the hood.
I would guess that your Ford E350 cutaway RV chassis is a 1986 and may have the engine pump. Most E350 cutaway RV chassis are one year older than the home title says. Check the VIN number as the number (letter) in the tenth position will tell you what year it is so you can get the right parts for it.
1987 should be an "H" and 1986 should be an "G".
Old 10-19-2009, 09:37 PM
docpec1's Avatar
The VIN shows a 1987 E350 cutaway. I do have a mechanical pump. Do you think the pump could be bad, of do you think that letting the vehicle sit causes the fuel to drain down??
I guess what you are saying is tht if I have a mechanical pump I don not have an electric pump in the tank. Is that correct??
Is it possible to put an in-line electic pump in the fuel line? I have a double fuel line (one fuel supply and one fuel return) that goes to the fuel pump on the engine.
What are your thoughts on adding an in-line pump??
Thanks for the help.
Old 10-20-2009, 08:06 AM
subford's Avatar
Quote:
You have never said what your problem is with the RV.
Not sure what you mean by "drain down". If you are saying it takes a while to get the fuel up to the carburetor after it has sit for a while it is normal.
Yes this is correct.
Yes I put one on my 1992 E350 RV.
That does not sound right, I have never heard of a mechanical pump set up that way. The mechanical pump should have a supply line from the fuel tank(s) and a pressure line going to the vapor separator and from the separator one line should return fuel to the tank(s) and one line to the carburetor.
You can put one on the frame between the tank selector valve and the mechanical pump. I would use a toggle switch to the pump so you can prime the carburetor before starting then you can turn it off after it starts.
I used a Carter Federal-Mogul Fuel pump and the number was M60318 or P74019.
I had the first number on the first one, it last about 2 years and the second number lasted about three years and was not working when I sold the RV. Yes I had a new filter before each pump.
Image of the hot gas vapor separator:
Old 10-20-2009, 12:18 PM
docpec1's Avatar
SUBFORD:
I do not have a mechanical fuel pump. I have a block off plate where the fuel pump should be. I still can not find the fuel pump relay UNLESS this wiring only uses the starter selonoid "I" terminal for power to the relay during starting. I am going to open the cabin hatch to see if I have an oil pressure switch (along with the oil pressure gauge unit). If I do, I will jumper it out and see if I can hear a relay or hear the pump running. If I can I will just put a pushbutton in that circuit an use it as a 'prime' switch.
Old 10-20-2009, 12:26 PM
docpec1's Avatar
SUBFORD:
I guess I didn't answer the first question you asked me. It takes about 8 or 9, 15second start cycles to get the engine to fire after is has sat for a week. That seems a little excessive to me. Am I wrong??
I should have said in my first email "IF I have a mechanical fuel pump - ect.". Sorry about the typo.
Old 10-20-2009, 12:28 PM
subford's Avatar
SUBFORD:
If you have the plate then you will have the relays unless someone removed them.
Image of the oild pressure switch:
It should be wired like this but the color of the wires may be different:
Old 10-20-2009, 03:21 PM
docpec1's Avatar
SUBFORD:
Success at last. I jumpered the oil pressure switch and finally located the fuel pump relay which was cleverly concealed near the passenger side apron behind the battery. I am going to add a pushbutton across the oil pressure switch leads to prime the engine after long idle periods. Thanks for all your help in this matter.
Old 10-23-2009, 02:52 PM
docpec1's Avatar
I would like to thank all of you who helped me solve my hard start problem. I have located the fuel pump relay and installed a pushbutton that allows me to 'prime' the carb. It works like a dream. Again, thanks to all.
Old 10-23-2009, 03:08 PM
subford's Avatar
Do you have a photo of the relays and their location to help out somebody else?
Old 10-24-2009, 02:07 PM
docpec1's Avatar
Almost impossible to take a pic of the relays as they are behind the battery and not enough light to get a decent picture. When I put the camper to rest for the season I will take a picture at that time as the battery won't be in the way.
Old 10-24-2009, 07:27 PM
Rod Bender's Avatar
Rod Bender Rod Bender is offline
Rod Bender is starting off with a positive reputation.
If someone can direct me on how to upgrade my membership so I can post pics, I can show you exactly where it is... I just had to replace mine, it is located on the passenger side next to the battery... Greg
Old 10-24-2009, 07:31 PM
subford's Avatar
Quote:
To post a photo on here just uplad your photo to some place like photobucket and then in your post on here just copy the link into your post. The link you post should start with [IMG] & end with [/IMG].
2001 E450 Crank but no start, able to start with ether mike_pop 1968-2013 Full Size Vans 8 12-23-2015 06:40 AM
1976 460 fuel pump Frank D Cunha Fuel Injection, Carburetion & Fuel System 2 09-16-2015 07:17 PM
1989 E350 Motorhome. Fuel pump woes. FordGuy90 1968-2013 Full Size Vans 16 03-28-2014 10:19 AM
87 E350 RV sending Unit Broken tekrsq 1968-2013 Full Size Vans 4 10-28-2011 05:47 PM
460 won't stay running ford2go Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 04-23-2006 09:43 PM
Tags
1999, 2005, 87, e350, electric, f150, ford, fuel, location, pump, relay, relaylocation, switch, systems, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
