5.4 litre plug thread ?
I have heard that prior to 2006, that the threads in the spark plug hole are only about three ( 3 ) threads deep, and a reason why the plugs get ejected.
The reason I ask is I have a 2007 5.4, and if I have something to look forward too, in a possibility to have a spark plug wanting to leave home?
Thanks.
Thanks.
Earlier 5.4's, namely 2 valve motors had the plug spitting problem. Not to worry your 07 does not have this plug issue. Depending on build date, you may be subjected to a plug change challenge, namely broken plugs. I think it's engines built after October (can't remember the specific day) 2007 have a different design and have Coil On Plugs that are brown.
Hope this helps
Hope this helps
ml_nelson
06-27-2011 05:20 AM
