Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Early Broncos (1966 - 1977) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-10-2009, 03:16 PM
0351mike 0351mike is offline
0351mike is starting off with a positive reputation.
Altenator gauge spikes
Hi all
Still struggling with the electrical system on my 70 wagon. When I turn the truck on- the altenator gauge reads 30 and then starts erratic spikes from 0 to 30??? What is going on here? All my gauges work besides the fuel gauge- I am getting power to the gauge- but when I put the test light on it it blinks about the same speed as a turn signal??? Can anyone point me in the right direction?
  #2 (permalink)
Old 10-11-2009, 12:10 AM
McLeod's Avatar
McLeod McLeod is offline
McLeod is gaining momentum as a positive member of FTE.
Are you refering to an amperage meter or a voltage meter?
__________________
Just Say No!
'93 F 150 - 5.0, E4OD, 4.56, 33" & 4" Rancho lift
'95 Bronco - 5.8, E4OD, 3.55, 265/75 15 Goodyear Wrangler SilentArmor (excellent tire)
'67 Bronco Roadster, 351w, 4.11's, 5 inch Skyjacker lift
  #3 (permalink)
Old 10-11-2009, 07:33 AM
gfw1985's Avatar
gfw1985 gfw1985 is offline
gfw1985 is starting off with a positive reputation.
Not quite sure about your "spike", but with the old style regulator it is normal for the amp gauge to jump at idle, headlights pulse. Switching to the later model electronic reg will cure that. Say one from a 78 Fairmont.
__________________
76 Bronco Explorer 289 Hi-Po
66 U14 Half Cab Bronco frame off in progress
  #4 (permalink)
Old 10-13-2009, 12:12 AM
Boba Fett Boba Fett is offline
Boba Fett is starting off with a positive reputation.
On the fuel gage... start by checking the sender. To to this remove the electrical line running to the sender and ground it to the frame. It the fuel gage reads full.... you know the sender is no longer operating. Let me know if this works.
On the factory ammeter...its really a garbage gage. First...start by checking the alternator with a voltmeter/multimeter. Put one of the leads on the battery neg terminal.... then the other on the stud on the back of the alternator with the truck running... see what the gage reads.... usually between 12.x and 14.x... is it stable or surging up an down? If it is surging I agree with GFW.... first thing to replace is the regulator especially if you are still running and old stocker....... Also does your rig have performance pulleys on it? They can also be the culprit too....... if the voltmeter is stable and over 14..... .the forget the dash gage..... those things barely worked... from the factory!
  #5 (permalink)
Old 10-13-2009, 07:59 AM
checking
I will check the alterator out and let you know. I tried the sender on both gauges- no power to the sender- getting power into the gauge- did not check on the way out- I going to have to remove the whole cluster today to check it. Also could the culprit be the duel tank switch? This truck is a 70, but has the later electronic setup on it- looks the same as my 79 F150
  #6 (permalink)
Old 10-13-2009, 11:10 PM
Definately could..... inside the dual tank switch are two contacts so that the guage in the cluster can flip between senders readings..... the contacts wear out over time.... you can probably check this with a test light... if you have power coming, but not going out then the dual tank switch probably needs replace.
  #7 (permalink)
Old 10-14-2009, 07:23 AM
fuel gauge/ alt gauage
Well- tested the output at the altenator- and seems things are normal so I am going to disregard the gauge. I also have a new voltage reg, which I will throw in the truck in case I need it. I am trying to put this thing on the road, but seem to hit one thing after another. I had an idea about the switch. If I take the wires off the tank switch and jumper one of the wires from one sender together at this point (like I only had a single tank) I should get a reading or at least power back to the sender right?
  #8 (permalink)
Old 10-14-2009, 09:02 PM
Yes. That should work..... Remember that if your dash guage still doesnt work try grounding the wire at the sender to the frame and see if the dash guage reads full. You could always have a back dual tank switch and bad sender...... You can also ground the hot wire on the dual tank switch as well and see if that causes you dash guage to read full.....
  #9 (permalink)
Old 10-15-2009, 09:50 AM
Thanks for the help- I will let you know what I find out
  #10 (permalink)
Old 10-16-2009, 06:20 PM
Fuel gauge
My guage still will not work. I have 1-2 amps coming out of the gauge. 1-2 amps (kinda blinking) at the sender. Grounded the sender- no movement. Does this point to a bad guage?
  #11 (permalink)
Old 10-17-2009, 07:50 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation
1966/77 Bronco Ammeter Gauge
What 1978 Fairmont came with an electronic alternator regulator as original?
None.
In 1982, Ford replaced all the previous alternator regulators used on 1963/64 Thunderbirds, 1965/81 passenger cars, trucks, Bronco's and Econolines with an electronic regulator.
E2PZ10316A .. Alternator Regulator-Electronic (Motorcraft GR540A).
E2PZ10316A replaced C3SZ10316A, C3SZ10316B, D4TZ10316A and etc.
The existing wiring harness is the same, with or w/o this electronic regulator.
When Ford did this, it p!ssed some ppl off...that wanted original style equipment on their vehicles (ppl with 1965/69 Shelby's, for example).
The electronic regulator's cover is flat, made out of aluminum and has MOTORCRAFT & ELECTRONIC embossed on it.
The simple solution is...just remove the original (painted either black or blue) regulator cover and install it on the electronic regulator. Then...no one will know the difference.
ALL 1966/77 Bronco's used the same ammeter gauge.
C5TZ10850B .. Instrument Cluster Ammeter Gauge / Obsolete
Fits: 1966/77 Bronco.
Fits: 1965/66 F100/1100 / 1965/69 N/NT/T500/1000 / 1967/69 F800/1000 ALL with the round speedometer.
ED BENNETT FORD PARTS in Lebanon PA has ONE = 717-272-8762.
ANTIQUE AUTO SUPPLY in Arlington TX has ONE = 817-275-2381.
DON SANDERSON FORD in Glendale AZ has TWO = 623-842-8762.
No other Ford Dealer or obsolete parts vendor has any.
__________________
Bill / Retired Ford Partsman (1962/97) / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2000 // Cars: 1928/79.
1934 Packard V12 Convertible Victoria // 2008 Fusion S // 2008 Edge SEL.
  #12 (permalink)
Old 10-17-2009, 10:36 AM
fuel gauge
So if I am getting power to the gauge- power out of the gauge, 2 volt at the sender, but not movement on the guage- and when I ground the gauge- no movement- what is this telling me- bad gauge, bad sender?
  #13 (permalink)
Old 10-17-2009, 12:23 PM
Just to make sure.... you pulled the wire off the sender and grounded it to the frame on a good ground (an area free of grease etc)
You have a hot lead into the gauge.... and coming out..... and then you ground the lead and the gauge doesnt move? Reason I only ask so you don't buy parts you dont really need..... it seems like you have a bad gauge.... the senders could also be bad also, but you will have to fix the gauge first. I would do one last run through on the fuse panel with a test light... the clip grounded the point running through each side of the old bus fuses.... if the point lights the light on either side of the fuse the fuse is good...... if everything checks out.... your gauge needs replace....
  #14 (permalink)
Old 10-17-2009, 03:56 PM
fuel gauge
Yep- 2 volts to the gauge- I unplugged the tank switch and jumpered the correct wires together to bypass the switch- 2 volts there and then tested both senders by pulling the plug and testing- 2 volts there. To gound I pulled the plug- used the hot side of the plug and ran a jumper from there to the frame- no movement on either tank- I am going to go out and give it one more try- If the gauge is bad where can I find one-I am sure it has been obsoleted, but Ford probally used the same gauge on all their trucks in the 60s?
  #15 (permalink)
Old 10-17-2009, 04:43 PM
Ford Parts Guru
Quote:
Originally Posted by 0351mike
If the gauge is bad, where can I find one?
See above. This info was originally typed in post #11.
__________________
Tags
71 , 95 , boba , bronco , cover , f150 , fett , ford , fuel , gauge , meter , spare , spikes , spiking , tire , truck , voltage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
