broken bolt in water pump - Ford Truck Enthusiasts Forums
Old 10-10-2009, 02:47 PM
bmacky14 bmacky14 is offline
bmacky14 is starting off with a positive reputation.
when i was taking off the water pump off of my 86 f-150 with the 302 one of the long main bolts broke inside how can i get it out ?
Old 10-10-2009, 03:00 PM
lew52's Avatar
lew52 lew52 is offline
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
Yeah thats never any good , if theres not enough sticking out to get a hold of the timing cover will have to come off . Then you will have to work it out . There never easy .The bolt goes thru the pump & cover & screws into the block ...Lew
Old 10-10-2009, 04:31 PM
798hand 798hand is offline
798hand is starting off with a positive reputation.
Hate to do it but
If u can't ez out it try putting the new pump on. I have gotten lucky before
Old 10-10-2009, 09:14 PM
truckrider814's Avatar
truckrider814 truckrider814 is offline
truckrider814 is gaining momentum as a positive member of FTE.
I just did my water pump and broke off the one stud bolt i needed to put it all back together had to take the timing cover off which worked out good cause i found out i need to replace the timing chain and gears so it acutally might be a good idea to take it off just to see since you got it apart anyways better do it now than later and break off another bolt then 30 bucks and my truck runs great. also taking off the timing cover will let you get the bolt out unless it's broken off flush with the block which then i don't know how to help but someone will chime in that knows.
My two cents
Kyle
Old 10-31-2009, 07:24 PM
i got the timing cover off and there is enough bolt sticking out to grab with plyers but it wont turn no matter what how can i get it out
Old 10-31-2009, 07:30 PM
Old93junk's Avatar
Old93junk Old93junk is offline
Old93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputation
Grab it with vise-grips.
Old 10-31-2009, 08:00 PM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
heat it up after soaking in rust buster overnight.
Old 10-31-2009, 08:04 PM
g_k50 g_k50 is offline
g_k50 is gaining momentum as a positive member of FTE.g_k50 is gaining momentum as a positive member of FTE.
Put the heat wrench on the motor, the hole needs to get bigger not the bolt.
Old 11-01-2009, 12:08 AM
squirt some pb blaster in there and leave it for 20 mins then try
Old 11-01-2009, 05:12 PM
thanks for the replys i got it out
Old 11-01-2009, 05:21 PM
quicklook2's Avatar
more details to help others, please.
Old 11-01-2009, 08:45 PM
i heated it up with a propane torch and then tapped it with a hammer and with vise grips twisted it left and right until it came out no problem
Old 11-01-2009, 08:50 PM
quicklook2's Avatar
thanks!!!!!!!!!!!!!!!
Old 11-04-2009, 08:55 AM
pintoches's Avatar
pintoches pintoches is offline
pintoches has a good reputation on FTE.pintoches has a good reputation on FTE.
I broke off 5 water pump bolts and cracked the timing cover on my 351. is propane hot enough or do i need some thing hotter. I got mad and walked away i will work on it more this weekend.
Old 11-04-2009, 10:32 AM
quicklook2's Avatar
anger and working on vehicles is not a good mix.
Water Pump Lower Elbow Bolts Torque Specs djed 1999 - 2003 7.3L Power Stroke Diesel 2 03-23-2016 07:17 PM
Remove water pump & timing cover on 302 Dashknob 1961 - 1966 F-100 & Larger F-Series Trucks 4 05-20-2015 08:25 AM
can't remove water pump - ideas? flapbreaker Cooling, Heating, Ventilation & A/C 2 08-01-2014 09:24 AM
help 5.0 motor water pump housing johndeere46 1987 - 1996 F150 & Larger F-Series Trucks 2 03-07-2013 06:42 PM
Thermostat housing bolts Epd444 1994.5 - 1997 7.3L Power Stroke Diesel 24 05-22-2012 12:32 PM
Tags
302, 87, block, bolt, bolts, broke, broken, f150, ford, pump, screws, stud, studs, timing, water, waterpump
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
