Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-10-2009, 09:48 AM
jeff9942's Avatar
jeff9942 jeff9942 is offline
jeff9942 is starting off with a positive reputation.
Loosing oil but not leaking anywhere
93 F150 302 5.0 SuperCab
I am loosing oil somewhere but there are no signs of visible leaks, no smoke. What are some areas that would be causing me to loose about a qt of oil a week. Truck runs fine but where is my oil possibly going?
When I first got the truck, changed oil took a trip that was 212 mi one-way. When I go home I was about 2 qts low barely reading on the dip stick. Yes I let the engine sit for about 2 hours before checking.
  #2 (permalink)
Old 10-10-2009, 11:58 AM
94MustangGT's Avatar
94MustangGT 94MustangGT is offline
1994 Ford Mustang
My Garage
94MustangGT is starting off with a positive reputation.
Are you sure its full to start with? You would think that if it were burning that much it would smoke, or at least smell like burning oil...How's your PCV valve?
__________________
96 F150 XLT - RC/SB - 351 - E4OD - 4X4 - 3.55's w/Rear LSD - Handling Package - Towing Package w/Super Cooling - Warn Manual Hubs - 31" BFG AT's
94 Mustang GT - 302 - T5 - Black on Tan Leather - Bullitt Wheels - Bolt-Ons - 9.2 @ 77.4
  #3 (permalink)
Old 10-10-2009, 12:04 PM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE. quicklook2 has a very good reputation on FTE. quicklook2 has a very good reputation on FTE. quicklook2 has a very good reputation on FTE.
did you put 6 quarts in?
__________________
"To believe is to know you believe, and to know you believe is not to believe." ~ Jean-Paul Sartre
  #4 (permalink)
Old 10-10-2009, 12:18 PM
Jermafenser Jermafenser is online now
Jermafenser is gaining momentum as a positive member of FTE. Jermafenser is gaining momentum as a positive member of FTE.
Is the dipstick the correct one?
Oil pan rusty? Bolts loose? Chassis soaked in oil?
  #5 (permalink)
Old 10-10-2009, 01:15 PM
pancake's Avatar
pancake pancake is offline
pancake is starting off with a positive reputation.
I say have a look underneath ive seen several of these trucks and even some of the v8 cars the oil pan will start to bubble and peel and the oil will slowly leak through the thin metal or maybe part of the pan gasket is out of place ...rear pan seal... if its coming out down below you will see the underside of the trans/crossmember/frame coated in oil
good luck with it
__________________
THE NEW TO ME MOBILE->99 f150 suprcab 4.6 auto 4x4 75k...
  #6 (permalink)
Old 10-10-2009, 01:26 PM
DBGrif91's Avatar
DBGrif91 DBGrif91 is offline
DBGrif91 is starting off with a positive reputation.
If your exhaust smoke isn't discolored, then there's a leak somewhere- it's just a matter of finding it. If you have a large piece of cardboard, place it under the truck after you've been running it for a while then go back and check it after an hour or two. It's not exact but it helps point you in the right direction.
__________________
"Official Project Stages: (1) Uncritical Acceptance. (2) Wild Enthusiasm (3) Dejected Disillusionment. (4) Total Confusion. (5) Search for the Guilty. (6) Punishment of the Innocent. (7) Promotion of the Non-participants."
-Unknown
  #7 (permalink)
Old 10-10-2009, 02:45 PM
jeff9942's Avatar
I am glad you said the PCV valve - that was the first thing I was going to replace. There is never any oil on the driveway - I have had the truck about a month. I will take a closure look to the underside but at first glance not much there. Thanks for the replys.
Yes my 94 has the oil pan rust out problem but temporarly fixed it with JB Weld until I get the time to spend 6 hours replacing.
  #8 (permalink)
Old 10-10-2009, 03:00 PM
quicklook2's Avatar
did you put in 6 quarts?
valve seals.
__________________
Tags
1996 , 302 , 351m , 50 , burning , f150 , ford , leaking , leaks , loosing , low , oil , ranger , smoke , truck , underside
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
