SD engines
Old 11-09-2009, 04:56 PM
Truck451's Avatar
Truck451
Truck451 is offline
SD engines
Why were the SD engines discontinued?
Were the SD engines offered in medium duties or strictly heavy duties?
Old 11-09-2009, 05:42 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,592 Likes on 1,297 Posts
Because they were crappy antiques.
The SDs were in the heavier mediums and heavies. Think F700 and up IIRC.
Old 11-14-2009, 12:07 PM
danger fx4 ranger's Avatar
danger fx4 ranger
danger fx4 ranger is offline
That's a two part answer. 1). Ford replaced the SD engine family with the 429 (the same family as the 460) in the early 1980's. The 429 gave more bang for the buck (or milage for the gallon) than the SD. 2). The biggest reason was diesel. When the Super duty was first introduced in the late 1950's diesel didn't have the popularity it has today. Infact, The 534's performance matched that of the Cummins diesels Ford offered in the N-series trucks offered during the early 1960's. As time went by, diesel's reliability and performance improved making it the engine of choice in large trucks. Anyone who has ever driven a SD powered truck will tell you they are large, heavy, thirsty, low reving engines which have no business in any vehicle other than a class 7 or 8 truck.
Old 11-18-2009, 06:42 AM
q240z's Avatar
q240z
q240z is offline
The 534 twin turbo & intercooled engines that came out of a 46' motoryacht I'm restoring weighed 1800#, as much as a Cat 3208 turbodiesel. I'm told that when the throttles were planted forward, there was an enormous sucking sound, the rear of the boat would squat and the nose went for the sky. Within a second or two, the nose would slap down and that beast would take off--it was a 40kt boat, which is extremely fast for a vessel of this size especially when you consider that this upgrade was done in 1972. The downside, of course, is that it would consume three gallons per mile at full speed whereas a Cat of similar power output might consume only one gallon.
03X
04-05-2016 05:10 PM
SD Dually
1999 to 2016 Super Duty
03-28-2016 05:05 PM
kengarchow
02-06-2016 09:09 PM
2011f250sd
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
25
11-12-2015 11:20 AM
You Betcha
06-26-2004 04:40 PM
Quick Reply: SD engines
